TELEVISION ONLY HORIZONTAL LINE APPEARS ON SCREEN
  • 2 more comments
  • Dane Charles Nov 25, 2007
    I turned on the TV and I heard a Pop sound, some fizzle sound and then I only had a Horizontal Line in the TV. Sound is fine, but no picture.
  • Anonymous Apr 01, 2008
    how da frik do i fix it?
  • al_howells Jan 20, 2009
    I also have the same horizontal line.
  • Anonymous Apr 10, 2009
    But were do I look for these items listed?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It is due to vertical section failure.
  • before you start any work reduce brightness to avoid crt burn.
  • please check some loose contact or loose connector.
  • check supply to vertical section
  • check parts in vertical output section
  • check vertical ic.
  • hope this will help.
  • good luck.
Posted on Oct 17, 2007
Two horizontal lines appeared near bottom of screen
You can spend $300 to $500 fixing this or just do the best thing most cost effective thing and replace the TV.
Aug 23, 2016 | Sharp Aquos Televison & Video
There is a line down the center of the screen
whether the line-shaped vertical or horizontal? if it appears a horizontal line on your side, it signifies the vertical rays do not exit the screen or your TV vertical part is not working. damage can be caused by IC Vertical, or in the vertical deflection coil yoke.dan if a line that appears is from top to bottom that indicates the horizontal section is not working, usually there is a problem of the deflection yoke is not connected or defective.
Jul 11, 2010 | Televison & Video
A multi-color horizontal line appears on screen
yes it sounds like one of the sus boards have gone or a buffer take to tv repair if you have no knowlage on how to repair
Apr 13, 2010 | Vizio L37 Television
The image disappears on my tv screen. A horizontal line appears.
You need to check the horizontal IC for deffects, possibly and most likely there are dry joints on the legs of the Horizontal IC. Have all the legs on the IC soldered nicely, this shud sort out your problems as you say you hit the TV then works. Try this before replacing the IC
Apr 16, 2009 | Televison & Video
3 yellow horizontal lines in upper 1/3 of screen on Sony KP-61S75
TV has problem in convergence circuit. Needs qualified technician.
Aug 03, 2008 | Sony KP-61S75 TV
3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Apr 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Black horizontal lines
Sounds as if you have a bad capacitor in the horizontal deflection or video circuitry. You can spot a bad capacitor in circuit with a ESR meter.Hope this helps.
Jan 16, 2008 | Mitsubishi TS-5545 55" Rear Projection...
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
591 people viewed this question
Top Televison & Video Experts
