Question about Quad Cycling
Starting problem with mini quadard 49cc
Mini quadard 49 cc model atv-2 wont start?
  • 906 Answers
Turn the carb screw all the way in and back it out 1 1/4 turns. This should work. if you need more... do it in 1/4 turn increments.
Posted on Jan 25, 2015
  • 82 Answers
SOURCE: 49cc 2 stroke runs for 20 sec. then cuts out
20 seconds is all that is required to drain the float bowl. You have a float bowl/needle valve problem.
Posted on Apr 29, 2009
ollie reece
  • 1167 Answers
SOURCE: I just bought a 2 stroke 49 cc atv. Everything was
hi mate are you mixing the bike with 2 stroke if not buy a mixing bottle with a ratio of 32/1 on ebay and buy 2 stroke and mix it up with petrol and oil if not the engine will seize also take the spark plug out and give it a clean with a wire brush and check the gap is ok and then put it in the plug cover and put the plug against the cylinder and turn the engine over and see if there is a descent spark if not replace the plug good luck
Posted on Jul 23, 2009
luckyluke78
  • 333 Answers
SOURCE: midi 49cc bike will not start. owners haven't
If it is still turning over all you probably need to do is service the carb and drain and replace tank with new gas.
Posted on Aug 10, 2009
  • 10 Answers
SOURCE: my midi quadard won't start.
are you getting a spark? if not change coil
Posted on May 05, 2010
hunter19_46m
  • 7482 Answers
SOURCE: i have a 49cc atv
Hi patandsheri...
Your problem could be numerous and none of them good.
1...Broken crankshaft
2...Broken connecting rod
3...Blown Head Gasket
4...Broken or stuck intake or exaust valve, also could have lost the lock pieces to hold them in place.
5. Broken timing chain or gear
6. Hole in head or hole in engine
Please take time to rate me
Posted on Sep 09, 2011
How do I fix my 49cc 2 stroke pocket quad it has
If you have replaced the spark plug then the possibilities are the ignition coil is weak or the starter mechanism is faulty.
See this site for details of parts.
Mini Atv Quad Parts 47cc 49cc Stock Replacement
Sep 15, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
Engine wont start on mini quadard 49cc model atv-2
A lot of guys are having trouble with that. If you have spark. disassemble the carb and clean it. then screw the set screw all the way in and back it out 1 1/4 turns. if you need more you do it in 1/4 turn increments.
Dec 24, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
Mini quadard 49cc model atv-2 pull start problem
a lot of guys are having issues with these machines. Most I believe are due to the carb settings. Turn the set screw all the way in and back it out 1 1/4 turns. Try that. if you need more you do it in 1/4 turn increments
Trying to start mini quadard 49 cc model atv-2
Try turning the carb set screw all the way in and back out 1 1/4 turns. If you need more... do it in 1/4 turn increments.
My 49cc wont fire over
My 49cc 2 stroke pull start scooter wont turn over
Aug 19, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
My midi quadard won't start.
May 02, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
My 49cc pocket bike starts but wont stay on when i give it gas?
That problem has happened to me to and i just ajusted the needle on the side becuase it was too rich or the breather on the gas tank sometimes that gets fratured and the gas fumes cant get out right
Feb 20, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Midi 49cc bike will not start. owners haven't started it for 2 years. please help!!
Aug 09, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Cycling Logo
122 people viewed this question
Top Quad Cycling Experts
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Quad Cycling Expert? Answer questions, earn points and help others
