BU10FVZS1 BUSH digital box refuses to respond to "undo standby" command, so my TV is permanently on standby and I can't view any channels. I have renewed the batteries in the remote control.
jomaru
  • 337 Answers
SOURCE: Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
Sometimes remotes have a switch to select tv,vcr,or cable,amke sure the remote is in the tv mode,other than that rare but remote receiver go bad and they have to be replaced,but before you call for assistance make sure the remote is communicating with the TV.It could be still good with other devices and not with the set.
Posted on Sep 27, 2006
  • 556 Answers
SOURCE: Bush TV 2137TSIL
go to & ask for manul http://www.television-remotecontrols.co.uk/tv%20remote%20control%20model/bush.htm you will have to give model no.
Posted on Oct 08, 2007
  • 16 Answers
SOURCE: TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Posted on Dec 07, 2008
SOURCE: My Sony Trinitron TV does not respond to remote control commands
the tv wont come on the standy timer light is on
Posted on Jan 02, 2009
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
My channel 7 keeps freezing and comes up with no signal sometimes for days when it's though my my bush digital recorder box. But when it's just though the tv channel 7 works fine. What's going on??
Different digital boxes and tv's have different levels of RF gain. Some need more signal and some need less to work efficiently.
Possibly your Bush pvr needs a much stronger signal than your tv so the available signal is permanently on the threshold of reception and atmospheric conditions will some of the time reduce the available signal when reception will become impossible for the box but still be above the threshold for the tv set.
Modern Bush is not reknown for being a high quality brand and the purchasers of budget brand pvr's often discover reception or performance problems in fringe signal areas. Because a single aerial must receive a very wide range of frequencies it will be more efficient for some channels than others and so one channel could be a fringe channel and another channel produce a very strong frequency.
The signal strength and quality can be checked for each channel by selecting options in the menu in order to check this theory.
The problem might be solved by replacing the Bush pvr with a premium brand or replacing your aerial for a more efficient type. One of my friends had five different boxes before he gained a satisfactory performance and another friend three boxes and still has problems.
My installation has a new high gain wideband aerial on top of my 3 storey house and a distribution amplifier in the loft to keep the input lead short and the whole lot connected by very good quality double-wrapped co-ax.
I had to add different amounts of attenuation for each box or tv set but in spite of the signal being on average too strong and needing attenuating there are still channels for which the aerial is not as efficient and providing only a weak signal.
Feb 09, 2015 | Bush Televison & Video
Need universal remote code for BUSH set top box bu10fvzs1
1850,1886,1893,1802.
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 23, 2014 | Televison & Video
Need code and instructions to programme Bush BU10FVZS1 freeview remote controld to operate Sony TV
0786,0765,0723,0754,0799 are the codes to check. If you wish to get more details, check this site. Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
Mar 24, 2013 | Televison & Video
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Stuck on standby
Neovia Neo-3775: Standby Led permanently on amber when powered up with no screen or sound. Does not respond to remote or to TV controls.My problem is same as Ed's posted in 2009 - any ideas?
Jun 22, 2009 | Philips TP2785C 27" TV
Tv lost picture and sound
TRY UNPLUGING SET FROM THE WALL FOR 1 MINUTE. PLUG SET BACK IN AND CHECK. IF PROBLEM PERSISTS TAKE IT TO A QUALFIED SERVICER. UNIT PROBABLY HAS A DEFECTIVE MAIN TOTAL ASSY.
Jan 12, 2009 | Bush 5693D 24" TV
How can I get Freeview Channels?
I have a Bush 6690D and I can confirm that it does have a built-in digital decoder for terrestrial signals (Freeview).
Have you checked whether ***********'s TV is set to digital mode ? The "Mode" button on the remote cycles between analog, digital and AV inputs.
Oct 23, 2008 | Bush DVD2038 DVD Player
Bush TV
SMASH IT UP
May 02, 2008 | Bush 2871NTX 28" TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
