CANON IR 400 BLACK 8 LINE IN FS PAPER AS A LIVE CRETARIA
jaylex
  • 417 Answers
SOURCE: printing problems
Hi there check that it isn't the drum unit by turning the machine off open the top cover remove the toner and underneath you will have the dev unit unplug and lift out then remove the transfer tray (the one you open if there is a jam) open side door remove waste tank then you have the drum unit now to remove there is either a push button or a screw do either one that corresponds and check the unit. If there is a black line on one side the only way to get rid of the line is to replace the cleaning blade as this has worn. you can clean the drum unit cleaning blade it may only be toner stuck under the blade all you have to do is rotate the drum the opposite way of operation and if you have to hand a air line just give it a blast failing this it will defently need replacing.
Hope this is of some help
Please rate me
Cheers J
Posted on Dec 31, 2007
Cogz
  • 1326 Answers
SOURCE: canon ir 400 photocopier
What is the sub error code E805-" " -007 is is a blown fan and a blown fuse on the DC control. " " -002 could be a broken connection or pinched wire under the adf pillar on the right rear near the fixxing unit. If your have more info. on the code let us known..... Good luck
Posted on Apr 14, 2008
  • 39 Answers
SOURCE: CANON IR 400 WEB ROLLER HOW IT IS FIXING.I WANT VIDEO FILE
That is a little question with a big answer. You first need to buy a web ($10-$30) and then replace the old one with it. This requires tools and if that appeals to you then I'll write the rest of this response, but it's a dirty job. The only tool you really need is a Phillips #2 screw driver. Else if this doesn't appeal to you then call a copier tech to do the job. Good luck either way.
Posted on Dec 17, 2009
Testimonial: "how to fixing the ir 400 web roller "
Cogz
  • 1326 Answers
SOURCE: Error code : E 604 of Canon IR 400
It means that you are having a problem with the hard drive boot up program... You will need to replace the hard drive.
Posted on Mar 02, 2010
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Posted on Aug 16, 2010
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
Service mode for cannon ir 400
Press the *28* you need to press the 2 and 8 quite quickly almost at the same time and its the * with the head shape around it not the star on its own.
Aug 02, 2013 | Canon IR 330 400 400S F1 FE1-5023 5020 Net...
Canon IR 2318 Copying Problem
My Canon copier IR 2318 has a problem. When it prints, comes out a dirty paper with texts just easy to be rubbed by a finger and disappear! No any error code shown, so what can I do to fix this.
Jun 26, 2012 | Office Equipment & Supplies
My canon IR 2018 copier is giving me system error 007
hi;
its a fixing film problem, your fixing film is not spining properly maybe its paper jammed inside try to clean paper jam carefully else you order new fixing film from canon
good luck
Oct 20, 2010 | Canon iR 2016i Black and White Copier
I have Canon IR 400 photocopier. My problem is -
This not really a problem. Canon Copiers have various counters that track the counts of Various sized papers. Long, short and the like. The only counter that really matters in the 101 or total counter. This the counter that tracks every piece of paper that goes through the copier. This is the counter used to track copy usage. If you have a service contract this the counter the dealership will use to track copies for billing. Ignore anything but the total counter.
Mar 22, 2010 | Canon imageRUNNER 400S Copier
Why spot in the copy? ir 400 canon
If its black spots on the copy it could be that your drum unit needs to be serviced or change. IF it's white spots it could be a problem with moisture in the paper. IF it is moisture doing a copy on the back side of the paper should come out clear.
Jan 21, 2010 | Canon imageRUNNER 400S Copier
Pls give suggestion for canon ir2016
Good Evening Sir,
Myself Rahul Sisodia I wellcome you on Fixya.com. Ok Sir as you told you see a black line when you print. In this case just check where you see the blank line if you see it vertically on right side or left side that means you have no need to change roller in this case just reffill your cartridge again. But if you see A Horizontal black line on the printout is probably the result of a dirty or damaged roller. Also you want to know where to purchase it but you didn't tell where you live in India..? If you live in delhi you can purchase it from Nehru Place or Wazir Pur. Both are specialist market for computer and it's accessories. I hope on this stage you have no doubt about your printer. If it is then I will be here just write to me. Have a good day
Nov 04, 2008 | Office Equipment & Supplies
15 people viewed this question
jasbo
jasbo
