Question about Jenn-Air refrigerator JFC2290VEM User Manual
Water build up in Freezer compartment during defrost
Water leaks from right side of lower freezer door area. Does not seem to happen when making ice or drawing water. water lays across lower rear portion of freezer and builds up ice then defrosts at some point
SOURCE: JCD2389DES Water Leak Problem
Once I saw that the drain tube went up over the coil before draining into the evaporator pan I decided to buy a small piece of flexible plastic tubing and re-route the tube so the water could freely flow down hill. It's been over two months with no additional problems. I can assume that since the water drains freely it doesn't stay trapped in the elbow freeze and the cause the collector tray to ultimately overflow.
Posted on Nov 24, 2008
SOURCE: Jenn-Air freezer leak
Apparently it is the drain behind the freezer panel on the inside and it is blocked. It needs to be unblocked and cleaned. You remove the food and the rear panel on the inside of the freezer. With a hair dryer (carefully) remove all ice build up and then unblock the drain line going to the pan under the refrigerator. The drain line can be cleaned with bi-carb and hot water (not boiling).
Posted on Dec 31, 2008
  • 531 Answers
SOURCE: water in freezer compartment
your drain line is clogged
Posted on Apr 02, 2009
  • 10865 Answers
SOURCE: ice build up at bottom th freezer
You are correct. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Posted on Aug 05, 2009
  • 44 Answers
SOURCE: water freezing on bottom of freezer
The defrost drain pan is plugged and not allowing the water to drain into the pan under the refrig. Remove the cover on the back wall of the freezer and clear the drain by flushing with hot water.
Posted on Mar 25, 2010
Water is building up on bottom of fridge
If you have water build-up on the floor of the food compartment, or ice buildup on the floor of the freezer compartment, you are probably suffering from either a frost problem or from a clogged defrost drain.
Remove everything from your freezer, including all food and any shelves. Do not remove the icemaker (if installed.)
Look at and feel the panel covering the bottom or back of the freezer compartment. Is it thick with frost?
On top freezer models, are the holes in the top of the food compartment that lead to the evaporator choked with ice?
Is there ice forming on, or lots of water on the ceiling of the food compartment?
If the answer is yes to any of these questions, there's probably a defrost problem.
If you suspect a defrost problem, first remove any icemaker that may be installed. You will see a removable panel covering the entire back or bottom of your freezer compartment. There may be 6 to 10 or more screws holding it on. In some units there is a light socket attached to the panel; you'll see this arrangement most often in side-by-sides.
If you start to get an unusual buildup of ice in one particular spot in your freezer, especially beneath the icemaker, check for water leaks.
Water leaking onto the kitchen floor not traceable to one of the problems in Chapters 4 or 6 may be from a leak in the icemaker or door dispenser water system. Icemakers have a water solenoid valve mounted on the back of the fridge, usually behind the back bottom panel, and a water tube that leads straight up the back of the fridge to the icemaker. Door dispensers have a similar water solenoid valve with a water tube that leads beneath the fridge and into the door through a hollow hinge. If your fridge has both features, it's usually a dual water solenoid valve. It can be simple or not-so-simple to fix, but basically it's just a plumbing job.
Jun 13, 2016 | Refrigerators
MAYTAG DOUBLE DOOR REFRIG
THE PROBLEM IS WITH THE AUTO DEFROST (IF THE FEATURE IS AVAILABLE) OR ELSE YOU HAVE TO MANUALLY DEFROST IT REGULARLY
Sep 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Water is leaking from an opening in the back surface of the freezer compartment and forming a puddle that freezes and then melts, dripping under the freezer door
If you remove the shelves and bins from the lower section of the freezer you will notice in the back of the freezer your drain pan is clogged. Turn off the freezer and use a turkey baster to add hot water to the pan until you clear the clog. This can happen when foreign object slow the water leaving the freezer during defrost and cause it to refreeze stop water from leaving the freezer. Not a big problem or difficult repair. Just clear the drain and remove all the ice from the drain pan. Could take 15 mins or so to complete this..
I hope this helps
Jul 26, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator leaking water from freezer compartment, freezing along walls of freezer, but running water out under door
Sounds like the defrost water drain is plugged up. It could be a piece of food wrapper fell into it, or something. What make and model is it? Top freezer? Side by Side?
Dec 30, 2009 | Refrigerators
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Water comes out freezer door
Defrost that drain with a hair dryer and remove the debris . That should solve the problem . The red you see ( this is normal ) , is the defrost heater , thawing out the frost on the coils . The defrost water HAS to go out the drain or it will freeze the opening and the defrost water will flow out thru the bottom of the freezer door .
Aug 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Nov 16, 2008 | Refrigerators
Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Jenn-Air refrigerator JFC2290VEM User Manual Logo
26 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
