Question about Samsung UN55ES6100/UN55ES6150 55" 1080p LED flat screen TV with built-in Wi-Fi
Un55es6150 black screen - Samsung UN55ES6100/UN55ES6150 55" 1080p LED flat screen TV with built-in Wi-Fi
Samsung 55" LED that has no picture but the sound works. Flashlight test can see the menu faintly while the TV is on. It is model UN55ES6150.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 27, 2016 | Samsung Televison & Video
Screen blank on x836 turns on screen blacksout help thanks
Black Screen, Working Phone [Solved] - Phones - Cell Phone General ...
www.tomsguide.com/forum/id.../black-screen-working-phone.html
Dec 14, 2015 - 12 posts - ‎10 authors
I turn my phone off and then turn it back on, same result, black screen. I then tookout the battery and put it back in, same result. I took the battery ...
Why is my screen black but everything else works ... - iFixit
https://www.ifixit.com/.../Why+is+my+screen+black+but+everythin...
iFixitThe Samsung Galaxy S3 is a multi-touch, slate-format smartphone with ... I have a problem with my phone i dropped it and it works but all i see is a black screen ! ... was fine but then a couple of mins. later the screen started turning pink and when I .... i dropped my gs3, the screen cracked & the screen stays black, everythimg ...
Phone stuck on a black screen during or after a call? Here's ...
www.smartmobilephonesolutions.com/.../cell-phone-shows-a-black-scree...
Is your phone showing a black screen after finishing a conversation and not allowing ... causes and better yet some solutions to fix this issue on your cell phone. ... phone up to your ear, so that the phone will lock (turns on the black screen), ...
Jan 04, 2016 | Cell Phones
Sound and picture go out after about 3-4 minutes. Then com back on after a few seconds then go out again and not return. What can this be?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 27, 2015 | Samsung Televison & Video
Why does screen go black or white by itself?
There are 3 step to repair black screen error
If you got black screen error then there is a 94% chance that your computer has registry problems. To repair black screen error you need to follow the steps below:
* Step 1 - Download a black screen error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair black screen error.
Here are the url of black screen error repair tool:http://www.FixError2010.com/ttfix-black_... Source(s): http://www.FixError2010.com/ttfix-black_...
Sep 22, 2015 | Computers & Internet
My new UN55ES6150 dims after a few seconds of being turned on. Is it adjusting to ambient conditions or is there something wrong with it? (It also seems to dim and adjust back randomly after the initial...
this is a feature called eco sensor. it will dim the backlight in response to light level in the room. go to advanced picture controls in the same menu and turn eco sensor off. meder's tv service...good success and God bless.
Sep 11, 2013 | Samsung UN55ES6150F
Why screen is black out.
On my Windows 7 laptop, I got problem of Black Screen of Death, Windows Boot Genius fix the problem without data loss! I vote it!
Jan 26, 2011 | Computers & Internet
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Samsung UN55ES6100/UN55ES6150 55" 1080p LED flat screen TV with built-in Wi-Fi Logo
132 people viewed this question
Jerry Greenberg
Jerry Greenberg
