Question about Sony Ericsson Walkman® W610i Cellular Phone
Device mgmt SonyEricsson Communication interrupted
Device mgmt. sony ericsson communication interrupted
Posted on Aug 11, 2010
C710 Code on Copystar 2030
C710 Interrupted Communication at the Destination. If you're the sender, it's happening outside your machine. Most likely, phone line.
Feb 20, 2008 | Copystar CS-2030 Copier
Hi, I have a problem with my Acer Aspire 5732Z laptop. Upon boot up, I get a blue screen saying there is an error with my computer, and the following file name appears: DRIVER_IRQL_NOT_LESS_OR_EQUAL Not...
It seems you have an IRQ conflict. You install a driver and it wants to use an IRQ which is already assigned to a different device. That's why you can start in safe mode because the drivers for your added devices are not loaded.
The computing phrase "interrupt request" (or IRQ) is used to refer to either the act of interrupting the bus lines used to signal an interrupt, or the interrupt input lines on a Programmable Interrupt Controller (PIC). The interrupt request level (IRQL) is the priority of an interrupt request.
In computing, an IRQ conflict is a once common hardware error, received when two devices were trying to use the same interrupt request (or IRQ) to signal an interrupt to the Programmable Interrupt Controller (PIC).
The PIC expects interrupt requests from only one device per line, thus more than one device sending IRQ signals along the same line will generally cause an IRQ conflict that can freeze a computer.
To view your current IRQ assignments you can open Device Manager. Click on START, click on CONTROL PANEL. Click on Performance and Maintenance. Click on System. Click on the Hardware tab. Click the DEVICE MANAGER button. Once you have Device Manager open, select VIEW from the tool-bar menu, and then click Resources by Type. Double click on Interrupt Request (IRQ). If you are experiencing problems with a newly installed/configured piece of hardware and the drivers are installed correctly, then check to see if it has its own IRQ channel.
To change an IRQ setting follow these steps:
-Right click on the device in the list (see above), and then select properties.
-Click the Resources tab.
-Remove the tick from the Use automatic settings option.
-Select a non-conflicting configuration from the pull down box.
-Click OK.
Dec 18, 2010 | Acer Computers & Internet
In my office we have a SHARP AR 5127 copier. i have replaced the cartridge and it's worked one month and after showing the error call for service U2-40. I want best solution. Plz. give me soluti
u2-40 is communication problem in mainboard,try to replace the toner cartridge. or reset by programming. here the programme...on the mechine then # interrupt 0 interrupt. if mechine go sleepmode pls press 14 and start.
Feb 11, 2010 | Sharp AR-5316 Advanced Digital Imager...
Floppy drive not listed in computer mgmt
Your floppy disk drive has failed. You will need to replace it. they are usually pretty cheap.
May 31, 2009 | HP Computers & Internet
Acer eLock Mgmt has my devices locked out.
This is a Quoye straight from the Acer knowledge base for the elock software...
If you forget your password, you will need to
take your notebook PC to an Acer Customer Service Center.
Apr 01, 2009 | Acer Aspire 4520-5582 Notebook
Device Management
if it indicates that it hasn't actually sent anything to us yet.
The common sync phases for Sony Ericsson devices are:
  • Synchronising
  • Sending
  • Receiving
  • Sync Complete
you would have to double check all of the connection settings in use on the device and also ensure they are correctly linked to the sync application (some devices require that the settings are enabled for the sync application).
Oct 13, 2008 | Computers & Internet
Software up dates for k800i
download the Sony Ericcson Update service from http://www.sonyericsson.com/cws/download/1/110/61/1211192682/Update_Service_Setup-2.8.5.12.exe
then install it, then follow the on screen prompts
Oct 05, 2008 | Cell Phones
Fax interrupts phone call
1. Make sure your [RINGS TO ANSWER] settings are more than the same settings for your answering machine.
2. If someone tries to make a copy while the phone line is in use, they need to press number 1, as if telling the unit that they want one copy. If not, the unit will think you are trying to receive a fax and will interrupt the communication.
Be blessed.
Sep 04, 2008 | Samsung CLX 3160fn All-In-One Printer
I just installed an alpine deck and all i get is the word 'interrupt' on the display and nothing will play.
When a device having the interrupt feature (such as a cellular telephone) is connected to the receiver, the audio signal will be automatically muted whenever the interrupt signal is received from the device. The supplied wiring harness contains a pink/black Interrupt lead that needs to be connected to the device's interrupt signal connection.
Jul 27, 2008 | Alpine Car Audio & Video
Sony Ericsson Walkman® W610i Cellular Phone Logo
372 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
