Question about EZAirwireless Ezview - Wireless PC to TV 1080P
EZAirwireless Ezview - Wireless PC to TV 1080P no drivers
Can you give the drivers please
Sony model KDL-70W850B crack screen repair cost
It usually requires getting a new digitizer which on a cell phone is cheapish but for a larger screen it can get quite pricey. If you post a pic i can give you better idea.
Nov 07, 2016 | Sony BRAVIA KDL-70W850B 70" 3D 1080p...
Where is the reset button?
The internal power supply that is inside the TV is defective.
Apr 27, 2015 | LG 60LN5600 60" 1080p LED-LCD TV - 16:9 -...
No power to the TV
Probably needs new capacitors on the PSU board.
Sep 20, 2014 | LG 60LA8600 60" 3D 1080p LED-LCD TV - 16:9...
Ezview driver
theres no driver for it. the company has gone. i can sell the driver for you (xp or win7). tested with ezview+ if you want it name your price and write me at aagi23@wp.pl
Feb 14, 2013 | MISC EZVIEW Ezair Wireless EZView 720p HD...
Are you able to use the VIZIO 47" Class 1080p 480Hz SPS LED Backlit LCD HDTV as a computer monitor and use a wireless keyboard and mouse to browse on a pc through rgb and speaker jack?
Yes, all new TV's of 1080p specification will have a dedicated PC connection (and should have either a 3.5mm audio socket or 2 x RCA inputs for audio).
The most common way is to use a VGA lead (with 3.5mm audio lead) - VGA out of pc to VGA in of TV. 3.5mm audio output of pc (ie headphone socket) to 3.5mm audio input of TV.
You will just require the correct VGA lead long enough to connect to your pc.
The wireless keyboard and mouse will need to be connected to your pc, and must be within "line of sight" to the wireless receiver.
If you specifically want to use pc output to RGB input (and RCA audio in) of your TV, then you will need to obtain a long VGA to RGB conversion cable, plus 3.5mm audio lead. Have a look on Ebay for a coversion cable.
Cheers,
"Please take a moment to rate this solution with a 'testimonial' and/or 'thumbs up', as this will keep my status active and allow me to continue offering technical support. Thank you."
Jul 31, 2011 | Televison & Video
Will not display 1080p from a Sony ps3??
Connect your PS3 through the HDMI 2 port on the TV and as a PC under the tv settings. Then auto setup the tv on the PS3 and it will now see it as 1080P. It will give you some error message whenever the PS3 is first turned on but it will work. Hope this helps everyone.
Ryan
Jan 20, 2008 | Mitsubishi WD62627 62" HDTV
EZAirwireless Ezview - Wireless PC to TV 1080P Logo
24 people viewed this question
Top EZAirwireless Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an EZAirwireless Audio Player and Recorder Expert? Answer questions, earn points and help others
