Question about Kohler Plumbing
Low water volume on a k-7980 alterna widespread lav faucet
Pulled both inlet supply lines from tee connection body below spout with good volume so there must be some way to clear debris , deposit inside tee body or if there are flow restrictors that need yo be opened wider
4 Suggested Answers
  • 409 Answers
SOURCE: I installed a Price Pfister kitchen faucet model low water pressu
yes it should have a flow restrictor in the end of the spout. You might need to clean it out
Posted on Mar 11, 2010
  • 299 Answers
SOURCE: Low water flow
Check the cutoff valves under the sink to be sure they are fully open. One could have gotten bumped when putting something away. This is particularly likely if only the hot OR cold is running slowly but not both.
Posted on Apr 20, 2010
  • 97 Answers
SOURCE: noise in hot water valve of a widespread lav faucet
Check the faucet washer.
Posted on Aug 23, 2012
Looking for a cold cartridge for 2 handle lav faucet.
We don't have any plumbing parts here! Check eBay, Alibaba, and Amazon, or consult your local hardware store.
May 12, 2015 | Plumbing
Faucet leaking at tee where hot and cold connect to spout
The designs of the Kitchen Sink Faucet mainly exhibit differences in its handles and spouts. Differently curved spouts and handles diversify the range of products. Some have long spouts and some are with short ones. The spouting of water may also give different flow patterns with the external fixtures. The handles are mainly in single or double.
source Best Kitchen Faucets
Feb 03, 2012 | Kohler Fort© Widespread Lavatory Faucet...
The T connection under the spout keeps leaking and no matter what we do, we cannot get it to stop. How do we fix this problem.
I'm not sure if you are refering to a T connection in the drain line, or in the water supply line.
I use teflon tape on all of my threaded connections.
I hope this will help you solve your leak.
Feb 18, 2011 | Kingston Brass KB959 Magellan II 4Inch to...
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
My 3 handle bathtub fauset [price pfisher] cycles hot and cold
You will need to either replace center "shower diverter"assembly or a quicker fix would be to remove old tub water fill spout and replace with a "pull up diverter knob" type water spout. Cost about 10 dollars Hdepot Pull Knob to divert water to shower when showering.
jthomefix
Mar 15, 2009 | Price Pfister Ashfield Widespread Bathroom...
Unable to pull spout to replace O'Ring in Kohler Faucet F10416
They just pull out, sometimes things get stuck and I cant get them lose as a plumber and you just have to buy a new one...dont feel bad
Jan 31, 2009 | Kohler K-10416-BN Fort½ Single Control...
Plumbing Logo
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
