Question about Spencer's Baby The Fart O Nator Extreme
The ****-o-nator remote doesn't work. I push the wow and the normal buttons but no ******* sounds.
The remote doesn't work. I put 4 batteries in the speaker. The speaker makes noises if I move it.
My remote won't work
Many remote controls freeze up and appear "Dead", but some can be instantly brought back to normal operation by following 4 simple steps.
Use these steps on OEM (original equipment) remote controls for TVs, DVDs, Audio Systems, Satellite and Home Theaters.
Note: If you follow these steps on a universal remote control, you will need your universal's owner's manual to reprogram it.
1) Remove all batteries from the remote
2) While the batteries are out of the remote, push and release every button on the remote control one at a time, until all buttons have been pressed and released at least once. This action drains the capacitors in the remote's circuits and causes the remote's brain to go back to factory defaults.
3) Re-install the batteries, taking care to insure each battery is installed correctly. Use new batteries if you are unsure about the batteries you removed.
4) If this Remote Re-Start procedure is going to work, your remote should now be back to normal. Try it.
If your remote works, Great. If not, you can shop for a new OEM remote control at Remotes.com 1 800 Remotes Factory original replacement remote controls
If you need codes for Universal remotes REMOTE CODES COM
Feb 29, 2016 | Televison & Video
Remote start
The remote is in the middle of its 'setup' re-programming cycle, one of you has accidentally put it into this mode. To switch it back to normal mode remove the battery from the remote for about 10 minutes.
Dec 15, 2013 | Viper 7251V 2-WAY LE RESPONDER REMOTE
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
Background noise problem with motorola radius cp200 and also crackling status during transmissions
Bill,
If the crackling and static are coming from the radio, it could mean 1) Something in your environment is putting out RF (radio frequency waves). 2) You have an old battery. 3) You are at the edge of the radio's range. 4) You have a bad speaker in the radio.
Possible solutions for you could be:
1) Have the radios reprogrammed to have Private Line (PL). This would block out RF noise on your frequency. Also, within the factory if there are devices putting out RF noise, there may be some solutions for them.
2) Replace old batteries. (Try a known good battery and see if it helps.)
3) Check to see if you have the same problem when radios are within a closer range. If it is a range problem, education yourself and other users to hold the radio upright (perpendicular) to the ground. You will get the best range. Tilting the radio can reduce range as much as 2/3s. Even the bodyfluid of a person wearing the radio can absorb range.
4) See if you have the same problem with another radio, or if the crackling static is just with the one radio. It may need repaired.
Another solution for you might be a noise canceling remote speaker mic. This would put the speaker of the radio up on your lapel. And these mics also have some noise/wind canceling ability.
There are a few programming things you could have your local dealer try. They may be able to tighten up the squelch and knock out some of the noise.
Best regards.
Mar 11, 2013 | Radio Communications
Hooked up my amp it has power but power light won't come on won't power up front speakers work and have sound but it doesn't move to back
Make sure the remote wire is hooked up. You can run a small wire from the power terminal to the remote terminal. If it powers up, then you have a remote wire problem. You can run a remote wire from the blue power antennae wire of the deck.
Apr 02, 2012 | 1991 Ford F250
New Bright, F-150, Red Thunder 4X4: Truck goes into "static" mode when forward or reverse is pushed on remote. In other words, truck starts up when turned on, steering, horn and lock work fine,...
Get new battery, I have 4 batteries, all will turn it on, get horn lights, sound. 2 do the exact same thing yours is doing, 1 runs about 5 min then starts into your problem, 1 is good and will run for about 20 mins.
Aug 27, 2011 | New Bright Ford F150 Rc
Our remote to the fan is not working
Try changing the batteries int he remote.
If anyone opened the battery box for the remote recently, the "DIP" switches may have been moved. These switches make the communication between fan and remote match - (in case you have several fans in the house, you only want one remote controlling one fan). You will have to pull the besel off of the fan (where the pole comes to the ceiling). You should be able to see a set of 4, 6 or 8 little slider switches on a small electric board. Make sure the switches are set the same on both the fan and remote. If they are set differently, they will not communicate.
If that doesn't work, there are many options of what can be wrong (bad remote, bad radio receiver on the fan, interference from other radios, ...).
Good luck,
-Mark
May 21, 2011 | Hampton Bay 24750 Huntington III Ceiling...
My dvr freezes. i have picture and sound but unable to change the channel or anything dealing with the dvr. i have to manually push the system info button on the box then select done with the remote. ...
Believe it or not, this could be a simple battery problem in your remote. When my battery is low in my remote, some buttons will work and some not. I'd try replacing the batteries in the remote first. If that doesn't work, I would guess that you need a new remote. Sounds like your DVR works fine manually, so chances are that's not the problem.
Hope this helps.
May 14, 2011 | DISH Network DVR-625 DTV Receiver /...
Have a low noise like hum when i turn on thump 15A It doesn t change by moving level but when I plug in anything it s feeding a noisy tale on every signal attack.
Make sure you are using BALANCED audio line to the speaker AND your mixer is powered from the SAME receptacle as this speaker. One MAY have to run an extension cord back to the mixer and othe equipment, but this must be done to reduce noise and also for equipment safety. Multiple recepatacles in a building have grounding issues that can generate noise or worse damage equipment due to ground loops. If you DJ mixer does NOT have balanced outputs, use DI boxes so you can use balanced lines to your speakers. Your cables will either be XLR or 1/4 inch TRS types, not just TS type.
May 14, 2011 | Mackie TH-15A Active DJ Powered THUMP...
My remote doesnt seem to be connecting with the system. whenever we push a button no light comes on weve tried new batteries and it hasnt work wat can we do
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12976414911881
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
If it works, Great!
If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Feb 13, 2011 | Bose Cinemate Digital Home Theater System...
Spencer's Baby The Fart O Nator Extreme Logo
188 people viewed this question
Top Spencer's Baby Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Spencer's Baby Water Sport Expert? Answer questions, earn points and help others
