Question about Toys
Assembly instructions for hot wheels criss cross crash
  • 17 Answers
Go to www.hotwheels.com Click on product instructions. Type in criss cross crash-Hit enter.Then you can click on exactly which model is your you own, and it will pop up your assembly instructions for you.
Posted on May 18, 2009
2014 Ford Fusion 2.5L, 2WD Torque Specs for front wheel hub assembly needed Axle nut/bolt, Hub bolts
the four axle nuts, 98 ft lbs, tighten in criss-cross pattern.
The hub nut/wheel bearing, 148 ft lbs, use new nut, don't let vehicle weight sit on the ground while torqueing, it could damage the wheel bearing.
If I left something out, give me a holler.
Jul 26, 2017 | Ford Cars & Trucks
I am having a problem with the installation of a Dyno by Minka Aire.
I am having an issue with assembling my Minka Dyno. I cannot get the flywheel to attach evenly to the motor assembly. When I tighten the screws (criss-cross) the flywheel lies crooked. I've tried twice but it's still crooked. Any help is appreciated.
Apr 22, 2017 | Dryers
I am having front end issues after replacing front end right side all of the parts but feel a wobbling and the front tires are criss crossing over the back
Did the person wwho ewplaced all the parts have mechanical experience?
Was everything tightened/torqued up to the correct values.
Are the wheel nuts secure
Jul 11, 2015 | Cars & Trucks
Am missing parts for Mattel Hot Wheels Criss Cross Crash Track. Need 6 curved track sections (Part number 2148-2050).
I don't have a solution to your problem with hot wheels but am wondering if you were Rosalie DeGraff 55 years ago when I knew you.
Nov 13, 2011 | Mattel Hot Wheels Criss Cross Crash Track...
Torque setting for 2003 Hyundai Sonata valve cover
the torque spec's are 71-89 inch pounds. start with the center bolts then work out in an opposite, (criss/cross) pattern, like you would tightening wheel lugs. please rate if this helped!
Apr 29, 2011 | Hyundai Motor 2003 Sonata
What is proper method for aligment of tires. is it front to back or criss cross.
If you have unidirectional tires it is front to back, ordinary tires are criss cross.
Aug 09, 2010 | 2005 Lexus RX330
How do i properly re-install the front wheel after tire change?
If nothing is wrong with the wheel, check your owners manuel for torque specs and tighten the lug nuts in a criss cross pattern to torque spec. Is this what you needed or am i missing something?
Jul 14, 2010 | 2008 Honda GL 1800 Gold wing Deluxe
Head bolt torque specs
For the 2.3 carb models:
Starting in the middle and working your way outward in a criss-cross pattern, 1st step - 58 ft-lbs, 2nd step - 72 ft-lbs.
For the 2.6 fuel injected models:
Starting in the middle and working your way outward in a criss-cross pattern, 1st step - 20 ft-lbs, 2nd step - 40 ft-lbs, 3rd step - 70 ft-lbs.
Mar 05, 2010 | 1994 Isuzu Pickup
Toys Logo
2,518 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
