Question about Hitachi 51F59 51" HDTV Projection Television
No sound on TV, but it works with a DVD
There is no sound on any of the stations. We checked all the connections and they are tight. The volume works when a movie is played but when we switch back to the TV, no sound.
Any suggestions will be appreciated.
Thank you
  • pmcclintock0 May 18, 2009
    After I posted the question we tried unplugging the set. It worked, must have needed resetting.
    Thanks for the suggestion, much appreciated.
    Problem Solver:
  • 18 Answers
Sonds very much like a dodgy scart lead to me had the same problem with boys tv
Posted on May 17, 2009
No sound on regular station
Check its system settings. If the TV is a multi-system one, set the system status to 'Auto'. Refer its user manual for details.
Dec 16, 2013 | Memorex MVDT2002 20" TV
Philips tv troubleshooting no sound and stays on mono when connected to antena model no 27ps55s121
did you check in the set up might set to off, if the settings is ok check the speaker if worn out. now if the speaker is still good at this time you will need to have trouble shooting in the amplifier circuit at the main board weather the amplifier is bad.
Sep 27, 2012 | Philips 27PS55S 27" TV
I have sound but no picture
Check the obvious first, such as whether the mute button is on or whether the volume is turned all the way down. If that's not the issue, try the following steps.
1. Verify that all cables are firmly seated by reinserting each one. Loss of sound from moving, adding, subtracting or bumping into equipment is common. It is particularly applicable if your TV is connected to an exterior sound system. Inputs require tight connections in order for you to hear audio.
2. Confirm that cords are connected to their appropriate plugs. Certain TVs have color-coded inputs that can be matched up with cable boxes and sound systems.
3. Try a new cable to see if that fixes the problem if other components appear to be working. Over time, cables can malfunction, either from age or from wear and tear. Having a spare cable or two around the house can be helpful for troubleshooting and eventual replacement.
4. Verify that the remote is set to:
Proper video input (TV, satellite/cable, DVD)
Correct audio input (TV, DVD player, gaming system)
5. Determine if it's the cable/satellite provider or TV station issue by checking other channels to see if the sound is isolated to a single station. You can also call your provider to see if they're experiencing issues with their audio before checking your own.
6. If an external sound system is used, testing another input such as a radio or CD player is a good way to differentiate problems between the TV and the sound system. There may be faulty inputs.
For more tips and tricks for restoring sound to your TV, check out No sound on TV for more troubleshooting steps. I hope this helps!
Sep 27, 2012 | LG 47LD500 47" LCD TV
+i cannot get the sound back on my (LG)TV ITS 50
Sep 20, 2012 | LG 50PT350 50 in. Plasma TV
Sound won't work
If your TV has a picture but no sound, start by checking the obvious such as whether the mute button is on or whether the volume has been turned all the way down.
Next check your cable connections and make sure everything is plugged in tightly.
Change channels to make sure that it's not a technical difficulty with your TV service provider or TV station. Call your service provider to see if they're experiencing issues with their audio.
Try reconnecting the HDMI cable after you turn off the TV.
Make sure your remote is on the correct input, and see if you have sound while playing a DVD or video game.
For a simple troubleshooting checklist, see No sound on TV and get more details on some simple fixes for this problem. I hope this helps!
Sep 13, 2012 | Mitsubishi WD-73735 Television
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
Sound output reduced
There is a volume control on the Remote of your DVD player , increase the volume in that and it should solve. Additionally check the audio output cord of DVD player if it is intact and tightly fitted.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Jan 22, 2009 | Sony DVP-NS57P
Hitachi 51F59 51" HDTV Projection Television Logo
50 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
