Question about Thrustmaster Computers & Internet
How do i align the thrustmatster tx racing wheel ferrari 458 for the xbox one
The wheel is off center it center alignment is 15 degrees counterclockwise
Yea dude I'm having the same problem
Posted on Dec 26, 2014
99 mercury grand marquis.the steering wheel does not return to center on its own. And the steering wheel isn't in right position when the wheels are straight.?
the return to the center on it's own is a result of the wheel alignment castor setting
if it set at zero or minus setting ( -1 degree) it has no action requiring it to return to center
To explain how it works --- the angle at which the king pin is set back ( positive degree) lowers the car
when turning a circle , the car is lifted up and loads up the king pin
when you let the wheel go that weight tries to fall down and that is the return to center position action
so to fix that problem , have a wheel alignment done and set at positive degrees ( normally around 1 1/2 degrees)
next problem is when you set with the wheels straight ahead there is no allowance for the camber of the road ( used to allow water run off in the rain) that means that if you position the wheel straight ahead when on flat ground then when driving down the road you will have the wheel slightly off center to allow for the car trying to run off the road from the road camber
it could also mean that if you have had suspension or steering work done that the steering was not centralized when the tie rod ends were adjusted for toe in adjustment and so the box /rack is now set slightly one way
it could also mean that the rear end is out of alignment and the vehicle is running sideways down the road ( crabbing)
the fix is to find yourself an accredited wheel alignment shop and have an alignment done properly starting by aligning the rear wheels first and then the front many will say not necessary but I can assure you that it is vital for tire wear and vehicle handling and if they don't want to do the job properly go somewhere else
Aug 08, 2016 | Mercury Cars & Trucks
Where is the battery located on a ferrari 458
if you can find the battery and know the correct procedure for attaching the jumper leads then there will be no problems
Dec 28, 2014 | Ferrari Cars & Trucks
Wheel alignment specs
This is just a free chat room
We have no info like that
We are at home & use the site-- the same as you do
Apr 08, 2014 | 2014 Ford Fusion
My Mitsubishi Lancer need wheel alignment, tell me, under what degree the wheel should be set up
castor angle 1/2 to 11/2 degrees
camber 0 to 1degrees
toe in 1/8 to 1/4
As it has to be done at a wheel alignment shop they will know the best settings. Make sure that they do the alignment on the rear first as it affects the front alignment
Jan 30, 2014 | 2003 Mitsubishi Lancer
Thrustmaster 458 italia racing wheel won't downshift
lay wheel on sit - look in front of paddle in slot- tiny push button switch sounds like its stuck- qtip and rubbing alcohol lightly
Feb 02, 2013 | Thrustmaster Ferrari 458 Italia Wheel for...
1994 f-250 4x4 7.5L 36x13.50 iroc swampers allinement shop said 6 degrees out of alinement what do i need to fix?
You need to ask them whether they are talking about 1 front wheel out of alignment to the frame or if 1 front tire is out of alignment to the rear wheels. Or are both front tires out of alignment in 1 direction?
You can sometimes have worn rear mounting bushings for the springs allowing the rear differential tube to canter to one side. This would be similar to the "dogwalk" condition that has the rear running off center to the direction of travel.
The best thing would be to go to a frame shop. The other conditions can mean the frame is tweaked or the rear tube is bent. You could try pulling the rear spring bolts, lay each one on a flat surface and turn the bolt while shining a flashlight under it. A slight bow in the bolt will allow more light to pass under the bolt. Then you will know if the bolt is slightly bent.
Once you know the problem, then you can do something about fixing it. If the right side front is +6 degrees off and the left side is -6 degrees off, the frame is curled to the right. A frame shop has the equipment to make bending adjustments. An alignment shop can only bolt on new straight parts the same as you can.
I hope I have helped give you some ideas; the Alignment shop should have told you more about your problem than its 6 degrees off. They would still have your business for the final Alignment after you worked on the truck, because an Alignment would still be needed.
Feb 25, 2011 | 1990 Ford F250
Crooked steering wheel on 2009 Pontiac G6, serviced twice, dealer says car is in alignment altho' the steering wheel appears pitching to left a few degrees, can this be resolved?
Yes it can be solved. All though your car may be in alignment how ever, they did not center the steering wheel prior to making any adjustments (it requires a little more work if you know what I mean), that's a part of the check list. You can fix by taken off the steering wheel but I recommend that you take it back and demand that they correct it. That's a prat of what you pay for when you taken in to get it aligned.
Sep 08, 2009 | 2009 Pontiac G6
1997 lumina how to do front wheel alignment
you set the camber by loosening the two bolts that bolt the strut to the steering knuckle move strut in or out check with camber gauge and tighten bolts when preferred setting is reached most cars are set around 0 degrees.Next you set the toe by turning the tie rods set toe on 0 while steering wheel is in the center.You need a alignment machine to do this correctly
Jul 24, 2009 | 1997 Chevrolet Lumina
Specs for the wheel alignment for a 2007 camry grande.
Well your Caster should be +2.2degrees to +3.7degrees Your Camber should be -1.4 degrees to +.7 degree and I recommend it be set at a 0 to a -.3 degree Toe in at straight ahead to toed in 1/16th of an inch.
Apr 12, 2009 | 2007 Toyota Camry
Computers & Internet Logo
168 people viewed this question
Top Thrustmaster Computers & Internet Experts
David Payne
David Payne
Are you a Thrustmaster Computer and Internet Expert? Answer questions, earn points and help others
