Question about THE SHARPER IMAGE Home
Can use in oven?
Can you use a dutch oven in the oven
What are the dimensions of t his dutch oven?
According to Amazon, the dimensions are as follows: 15 inches in length, by 13 inches in width, by 9 inches in height/depth. It also weights 13.8 pounds.
Feb 16, 2014 | Tramontina Gourmet Dutch Ovens: Enameled...
Find artifact images
In cooking a dutch oven is the original slow cooker. Usually made from cast iron, and can be used on top of a wood burning stove, in a wood burning fireplace, over a campfire, or with coal/charcoal. Some have domed lids, while others have a flat lid with a raised edge (aka flagged lid) which is idea for holding charcoal above the kettle. This allows for heat both above and below the dutch oven. These are generally available in stores such as Cabela's, BassPro and others.
Dec 02, 2013 | Ovens
What is the best shape for a dutch oven?
The best kind of Dutch oven to invest in is one that is round and wide. It should have sides that are more straight than sloped. This is in order to have a lot of room for searing/browning. The oven should be 4 " deep.
Oval dutch ovens will cause the food at the ends of the oval to cook unevenly when searing. An oval oven is good for pot roasts and whole poultry.
May 01, 2013 | Home
Does a braiser look like a dutch oven?
Braising has no liquid or at maximum, just a little, so the sides of the braiser are much more shallow than a dutch oven's. this way the meat doesn't cook like a stew in water, but rather from the steam.
Jan 14, 2013 | Home
Is there another name for a dutch oven?
Sometimes dutch oven are called slow cookers. They both have the ceramic pot but slow cookers tend to be electric, not for use on the stove or in the oven.
Jan 10, 2013 | Home
What kinds of foods can I make in dutch oven?
You can make so much in a dutch oven. I use mine to make chilli and soup mostly. But you can make all sorts of things like brisket, goulash and even french toast.
Jan 10, 2013 | Home
I need a replacement cord for my Rival SD165 Dutch Oven Skillet...where can I get one?
Visit http://www.rivalproducts.com . You will be able to locate there the nearest authorized service and parts dealer in your area.
Regards.
Jun 16, 2011 | Rival SD165 Dutch Oven Electric Skillet
Home Logo
611 people viewed this question
Top THE SHARPER IMAGE Home Experts
Donni Steen
Tom Chichester
Are you a THE SHARPER IMAGE Home Expert? Answer questions, earn points and help others
