Question about Sharp AR-5320 Black and White Copier
Screen blinking H2
It over load problem I feel, i just forgot to use code sequence ie #-intrupt - C or so, Kindly help
the m/c is being used in a chritable education institute.
regards
    New Friend:
  • 91 Answers
[#] [interupt] [c] [interupt] [1] [4] [start]
Posted on May 18, 2009
1997 yamaha venture 600 diagnostic light flashes and runs poorly need help
Typically the flashing is in a sequence of consistant, short or long blinks that represent a number. This number ie; one long and two short blinks =12, 8 consistant blinks=8 and so on.....represents a trouble code that will be listed in a service manual for your model and lead you to the problem component or circuit.
Jan 07, 2013 | Motorcycles
P0751 obd code hummer h2
  • Shift Solenoid "A" Valve S1. the transmission is going to have to be pulled, opened up and that shift solenoid replaced, sorry.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 12, 2011 | 2005 Hummer H2
How to reset SHARP AR5320e counter reset back to zero thanks...
hello i think sharp 5316/5320 their have no feature to reset counter
but try this code some time it help you press # ,intrupt button ,C ,intrupt button then you enter to service mode then,
press 24 press start button then press 8 start key then copy coun value is reset to zero and displayed on the 7-seg.then press intrupt key the machine goes to sub code input standby mode.pressed CA key simulation is terminated.
Jan 18, 2011 | Office Equipment & Supplies
Error Code H2
H2 means the thermistor is open or defective.
Try to press the copy button when h2 appears you'll see the sub 00. You dont need to replace the whole fuser unit. Try first to cancel the trouble by entering the simulation.
Try to press the # - interrupt- C- interrupt (one after the other.) then enter 14 then copy button. If it doesnt work replace the thermistor.
The last part that you'll replace is the main board but that rare. Mostly the thermistor is defective when that trouble appears. Hope it could help you a lot.
Jul 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
H2 Error Message on AR M205 Sharp Copier
hi..there is a problem in the thermistor,thats why you
get the error code as H2.
check this out..
thank u..
kindly rate my response..
Jun 23, 2009 | Sharp AR-M205 Copier
Hummer H2 SUT DTC Code C0563
u need to change/service the air compressor in ur car.
or it might be the air bags/sensors thats located next to the rear tires.
May 29, 2009 | 2005 Hummer H2
AR5316E error code h2
hi in put # + inroput + c + intrupt + 14 + start
Mar 07, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
XC 830 copier
Try this : press clear intrupt clear intrupt buttons in this sequence and after that 14 start. if the fuser is ok machine will run if you still get the code its fuser needs repair. for more support write to jagpal_65@yahoo.com
Jun 06, 2008 | Office Equipment & Supplies
Remove error in AR-5316
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Apr 15, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5320 Black and White Copier Logo
78 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
