Question about Kenmore 95002 / 95004 Electric Kitchen Range
Ears Kenmore model 790.94423300 stove oven will not work, but top burners do. will not work on bake, broil or self clean
philbran
  • 242 Answers
SOURCE: kenmore oven and brolier will not work
The problem lies within your oven control board. This is very common and are not very hard to replace but they are expensive. You can check the price of a new control board at sears parts.
Posted on Dec 30, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore gas stove model 790, the oven will not
It appears your thermostat/probe has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore gas range will not stop beeping showing F9 in window
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%^
SOURCE: Kenmore electric range 790. Both the broil and
Kenmore oven 790.91072601, bake & broil not working, relays are cycling but no heat... Sounds like I have the same problem but its the night before Thanksgiving and Iam in panic mode... I've orderd a new Temp Probe part # 316233902. did you ever get yours fixed
Posted on Nov 24, 2011
I have an electric stovetop and did a self cleaning it would not unlock so i turned off breaker and was able to unlock when i did the baking element was so brittle that it snapped and now all the burn
Ok,... First, and foremost, stop using the self clean. It takes the temperature up to 900 deg F, and creates all sorts of other problems with the lock motor and the walls and the bake/broil elements. Use a Low odor Easy-off spray cleaner to clean your oven from now-on, please.
Now, the bake element needs to be replaced. If you have the model number (found on the body of the Range behind the lower drawer, if you pull it out) I can look-up the manufacturer's suggested part to be replaced. You may also need to replace the broil element, but that usually is the last element to burn-out as most people don't use the broil function of an oven.
You will have to pull the range away from the wall, and unplug it before you attempt to replace any parts. No need to have 240 VAC/30 Amps running through your body. There are several black 1/4" screws that secure the back panel on the oven section to the body (about 6 to 8) and they will have to be removed to pull and replace the wires on the oven bake and/or broil elements. You will also have to go to the oven door (on the front of the range) open it, and remove the two 1/4" screws that secure each element to the body before you can change-out the element(s). The most popular bake elements for GE Ovens are part #WB44K10005 and/or WB44T10010, but there are other Bake elements. Will need the model of your Range to ID the correct element and the cost.
Now as for the rest of the burners on the stovetop not working, they are usually independent from the oven functions, which are wired into the controller in the center of the range control console, but there are a couple of GE models that wired the stove burners into the oven timer/controller. If this is the case, then you may also need to replace the oven timer/controller.
If the stove elements are independent and are only wired to the Infinite switches that control the front left, rear left, front right, rear right burners, than the problem is either with the actual radiant heat burner elements or the infinite switches that independently control each burner. I would still need a model number for the Range to help you more with this.
Hope this is of some help.
Dave
Dec 01, 2014 | GE Stove / Oven / RanMain Top Assembly...
New Kenmore elite range blows cold air from oven vent when top burners are on. Is this normal
That sounds a bit unusual.... Does the fan come on when you turn on the oven on bake? How about on broil? How about on self-clean. If it comes on in all those settings, then it may be working as designed. If NOT, they there may be a crossed wire, or you may have a malfunctioning control.
Nov 11, 2014 | Kenmore Kitchen Ranges
Stove does not work
sounds like youtr circut board is burnd out.also im not sure if youre model but some frigidair stoves had a callback because of the short problem .the were seting houses on fire.call youre local appliance dealer and see if youre model falls under this catigory.if i were you i would not use this unit it could result in a electricle fire untill you contact local dealer.
Apr 07, 2013 | Kitchen Ranges
I have a kenmore electric stove. The top burner
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
May 12, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Nov 28, 2008 | Ovens
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
bad oven ignitor is the most common cause of bake failure, located onthe side of hte burner bar itself, if youd like with a multi-meter, you can check the wires leading to the ignitor for 110v. if you have power and nothing was glowing from ignitor theres your problem
Nov 23, 2008 | Kitchen Ranges
MAYTAG GAS RANGE MODEL # MGR5765QDW
sounds like a bad bake ignitor, common issue with all gas stoves.
Nov 05, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Product manuals
Product manuals are available for most in-stock items.
Order a product manual by calling 1-800-366-PART (1-800-366-7278). Or download a free product manual at ManageMyHome.com.
Aug 01, 2008 | Kenmore 33169 Gas Single Oven
very likely your oven control it does those things without any input from the oven so if it doesnt do what it is supposed to it is likely bad
Aug 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 95002 / 95004 Electric Kitchen Range Logo
41 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
