Question about Hyundai Portable Generator: 2000-Watt Portable Inverter HY2000si
Hard to start - Hyundai Portable Generator: 2000-Watt Portable Inverter HY2000si
1997 Malibu 3L V6 Suddenly hard to start Suddenly hard to start
Could you give more detail as to what it's doing exactly? Is it having a hard time cranking the engine or does the engine crank but not want to get started?
Aug 01, 2008 | 1997 Chevrolet Malibu
Does a Goodman DSXC180601 5-ton A/C unit require a hard start? System has a TXV. I have been told hard starts could void the warranty
hard starts are not mandatory but they do help to save the compressor if it is having a hard time starting
its just a boost to help it start
and it shouldn't void your warranty they are to help it start nothing else
Apr 19, 2015 | Goodman Heating & Cooling
Car is hard to start and when starts chugs and brake becomes hard to push
Sounds like bad vacuumed leak because of brake being hard.check that the hose from power brake diapham on fire wall to intake manifold in on not got a hole in it and if it seems ok pull hose off brake unit and plug and start.good luck.if that solves it replace brake booster.
Mar 22, 2014 | 1999 Cadillac DeVille
It's not hard to start..it's hard to go in 2 and 3 gear
After start go to D and then to 3 and 2. Usually 3 should get you enough power up or down a hill. What is hard about changing gear?
WHAT vehicle is it?
Jul 20, 2013 | Cars & Trucks
93 gmc jimmy hard starting
"Hard starting" is a very vague description of the problem. There are MANY things that can make an engine hard to start - ranging from a weak battery to a bad fuel pump, to worn-out spark plugs or a plain, worn-out engine...
The only "solution" I can offer at this point, would be to recommend doing some diagnostics to determine at least which system in your vehicle is the cause of the hard starting.
May 26, 2012 | Cars & Trucks
1997 chevy venture hard to start
"hard to start" is a very vague description of the problem. There are MANY things that can make an engine hard to start - ranging from a weak battery to a bad fuel pump, to worn-out spark plugs or a plain, worn-out engine...
May 25, 2012 | 1997 Chevrolet Venture
What does "hard start" mean
The compressor is having trouble starting. You can wire in a hard start kit to help the compressor start. Its easy the hard start has two wires one goes to Common on the capcitor and the othe goes to the HERM terminal on the capacitor.
Jul 19, 2011 | Heating & Cooling
My hard drive is "hanging up" and sometimes does not start. The computer will start, keyboard light momentarily lights but hard drive will not start. The only way I can seem to get it started...
There is a possibility your hard drive is failing.Go to the website of your hard drive manufacturer and download a diagnostic utility. Run the diagnostic utility to determine whether the hard drive is in good condition.
Nov 10, 2008 | HP Computers & Internet
Hyundai Portable Generator: 2000-Watt Portable Inverter HY2000si Logo
21 people viewed this question
Top Hyundai Electrical Supplies Experts
john h
fred_therese
Are you a Hyundai Electrical Supply Expert? Answer questions, earn points and help others
