Question about Miele S7210 Bagged Upright Vacuum
Broken foot switch - Miele S7210 Bagged Upright Vacuum
Oreck vacuum repair manual
Unless you have a foot switch, the on/off switch for most Oreck vacuums are up in the handle. You will have normally 6 screws that hold the handle halves together. Take the screws out and then split the two halves apart and you will find the switch inside at the top front of the handle. You may have had a wire come off of the switch and it just needs to be plugged back onto the switch and then you can re-assemble the handle and you should be back in service. If you have a foot switch, you might need a meter to check continuity throughout the vacuum because you may have a broken wire somewhere. Hope this helps you solve your problem.
Jul 20, 2014 | Oreck XL Ultra Bagged Upright Vacuum
S5602 shut off
The switch is probably broken. try a flat screw driver up under the foot switch and see if the little button is missing. If the foot switch is not making a click sound when pushing on it the switch is broken. I have found on some of the vacuums I've worked on the on/off switch is not broke. There is a little button about the size of a candy cig and 1/4 " tall and there is usually a rubber spacer with a spring that holds it up off the switch. If one or both pieces are missing that's your problem.
Dec 19, 2013 | Vacuums
The power button on my Dyson DC19T2 won't stay on
The switch is broken. If you are handy, remove the old switch and match it up at a hardware store or a Vacuum repair shop. It shouldn't cost much to have it replaced by a proffessional either.
Nov 18, 2011 | Dyson Vacuums
Best place to get a eureka vacuum techical manual. my eureka lost power am unable to turn on.
ofen it is the power switch is stuffed you may need to replace it... some vacums with foot switches to turn on and off get broken due to people standing on them to hard etc.... it bends the contacts in the switch... hope this helps
Feb 26, 2011 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a Electrolux canister model L-E (circa 1986). Won't turn on. I think the foot switch is broken inside. Was working fine - turned it off then would not turn on BUT foot switch sounded different,...
I have one of these LE models also. Yes, the on/off button is broken. I have had to replace it twice on mine. My local vacuum repair shop suggested NOT to use your foot to operate this switch, but just press it on or off with your fingers. That will help to keep it from breaking.
Jan 10, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Sebo Felix Premium Vacuum cleaner brush will not spin. Not the belt, already checked.
Just the other day we had a customer bring a Felix in to our repair shop with the same problem. Although she'd had the Felix for several years, she'd never realized that one of the buttons on the base is a foot-operated switch (the left hand one as you see it from behind the machine). Hers had been "on" from day one, and never been switched off... until she'd obviously inadvertently pressed it without noticing and switched it off. Then she thought something had broken.
It may be as simple as that. So, does the green light come on when you operate the foot switch? If it does, and the brush doesn't spin, you have most likely got a problem with the motor (or possibly the circuit board) in the base. If the green light does not come on, there is most likely a poor (or broken) electrical connection where the bag compartment plugs in to the base.
I'll gladly try to be more help if you want to post more details.
Jul 07, 2010 | Sebo Felix Classic Bagged Upright Vacuum
The foot release latch has broken or become unlatched on my uprig
I had this problem once before. The only thing I did was loosen the back 2 screws, take the release latch and just play with it until it catches, rea simple.
Mar 19, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Electrolux 2100 foot switch
The owners manual is HERE: http://www.aerusonline.com/service/manuals.cfm
But it does not show the inside of the foot/power switch
Mar 03, 2009 | Vacuums
Miele S7210 Bagged Upright Vacuum Logo
23 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
