Question about Royal 10X Shredder
Does not run forward
Shredder runs in reverse, but not forward
  • 883 Answers
SOURCE: Shredder motor seems jammed
must disassemble feeder unit and visual check for jam. The debris may be a part of the shredder that has broken off.
Posted on Jun 21, 2007
fellowesrep
  • 102 Answers
SOURCE: Only runs in reverse
please post brand and model
Posted on Feb 23, 2008
rezazadeh
  • 328 Answers
SOURCE: A Royal crosscut shredder that usually only runs in reverse
in the middle of the paper enterance clean sensor
Posted on May 23, 2010
  • 1218 Answers
SOURCE: Royal Orca 9512x shredder will not run. I have
If motor wont run at all then probably the pcb is blown...call Royal at 1-800-524-0799 for parts and prices.
Posted on Sep 05, 2010
  • 1218 Answers
SOURCE: My Royal 12X paper shredder
If cleaning the eyes did not help then you will likely have to change parts ...you can contact Royal at 1-800-524-0799 for parts and pricing information.
Posted on Oct 29, 2010
Activa MD460 shredder misaligned?
they are not made to shred credit cards .
Jan 10, 2016 | Shredder Office Equipment & Supplies
Why does my intimus 602 shredder only run in reverse
This applies if Reverse is forward, and forward is running in reverse. If someone worked on it they may have reversed the wires from the motor to the board. There are four wires from the motor, of the four one goes to MZ on the board, another one goes to MV. If you swap these two wires you will be running in the correct direction again.
Aug 14, 2014 | Intimus 602 SC Shredder
Infoguard shredder SX-102 runs in reverse but not forward
Shredders have a manual switch for reverse..... if you have tried this, then there could be a possibility that the switch has dust of paper in it and the contacts not making contact for the reverse cycle... or the switch is faulty. If you have any electrical knowledge, you can do a test with an ohm meter for continuity in the reverse mode.... or remove the switch and blow it out with an air compressor. If you mess with electrical, ALWAYS REMEMBER TO UNPLUG THE SHREDDER!!!
Good luck.........
Jul 14, 2014 | Achiever CCS5000 Shredder
Our shredder motor is working but it will not go forward to shred. It will reverse. I've unjammed every visible paper jam but still nothing. HELP!
If it wont run forward but does run in reverse you may have lost the PCB inside.... contact Royal at 1-800-524-0799 for parts assistance and pricing.
Nov 29, 2010 | Royal CIA 12X Shredder
I have a simple Royal paper shredder. Got paper stuck in it. Going back and forth the paper appears to be gone, and it grinds normally in reverse but going forward the green light is on but nothing will...
Does the machine even run in reverse???? Have you ever oiled the machine.???
Put some "shredder oil" onto the cutting blades while it is running in reverse then try running it forwards.
If you can hear the motor running but the cutting blades dont turn you will have to open it up to see what is broken.
For parts assistance you can contact Royal at 1-800-524-0799.
Nov 19, 2010 | Royal VF1012mx Shredder
VF1000MX Shredder: Shredder works briefly in reverse, but won't run f...
Try cleaning the "eyes"....if they get dirty they can act erraticaly...if that dosn't fix it you may have a pcb prob....you can give Royal a call at 1-800-524-0799 for parts information and advice.
May 16, 2010 | Royal VF1000MX Shredder
The shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Jun 12, 2009 | OfficeMax 0M96431 Shredder
Model 12x royal paper shreddewill run in reversre but not forward
move the control button on top of the shredder to the oppoiste direction.
Nov 28, 2008 | Royal CIA 12X Shredder
Royal 10X Shredder Logo
82 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
