Question about Canon PIXMA MX850 multifunction InkJet Printer
I cant get it to print from the cassette I cant get it off cridit card print
I can't get it to print from the cassette. I can't get it off credit card print
  • sarassherman May 18, 2009
    It was about the problem but it did not fix it. I hope I am not being charged.
  • jackmacf May 11, 2010
    MX 8850
  • 4,889 Answers
Hello Sara,
I was is a session with you earlier. Apparently you had a disconnect. Ok.. here's what you have to do flip the "feed switch" to cassette. IF you dont know which one is the feed switch I took this capture from the manual its button number "22"I cant get  it to print from the cassette      I c - 1f0ad85.gif
Please let me know if that has resolved the issue. Will be glad to help if does not. Sorry about the disconnect wonder if its on your end or the server.
Posted on May 17, 2009
  • 2 more comments
  • eagle338
    eagle338 May 17, 2009
    Why did you end the session? Did you close the window by mistake? If so please post the request again as you have previously done..
  • eagle338
    Do you mean you want to print from the memory card? If yes then press the memory card button(number 5 in the image above) and it will switch the printer to memory card mode.
    There is a component called "cassette" which is a paper source.If that is what you are talking about you can use the button number "22" in the image above to toggle between tray and cassette. Let me know if you need more help
  • eagle338
    If you mean it prints the size of a credit card(just a small box instead of full page) then you should use the Settings button(number 10 in the image above) and then select the "Page Size" option and set it to a larger size like A4. I think its set to a small size like 4"x6" or something like that
    Read page 16 of the manual below for more help.
    http://gdlp01.c-wss.com/gds/0300000657/M...
  • eagle338
    eagle338 May 18, 2009
    Changing the page size did not work or you couldn't figure out how to do it? If that the case please let me know and I will walk you through it.
I have a Canon Pixma MG5420. I would like to print index cards using the upper cassette but I can only get the printer to print from that cassette using photo printing software. Otherwise I can't access...
Try opening control panel>devices&printers. Set the paper feed to the upper feed as permanent. Then on printer itself make sure that paper type, size and feed is where you want it.
Oct 28, 2013 | Canon PIXMA MG5420 Inkjet Photo All-in-One
Prints from wrong cassette
Have you tried setting the paper size for each cassette, then setting the printer to Auto instead of selecting the cassette?
May 15, 2013 | Epson WorkForce WF-7520 Wide Format...
I dont have the cridit carte
If you don't have credit card you buy from a nearest retailer. You can pay by cash or cheque.
Jan 14, 2011 | HP Computers & Internet
Printer Canon LBP3300, When was printer it show "Load custom paper in manual feed slot". Have try to slot manual feed but also cant work. Please help to solve this problem. thanks
Load Legal paper in Cassette 1.
If you want to print using only one piece of paper currently loaded in the Manual Feed Slot, click [Resolve Error].
If you want to feed paper from the cassettes, remove the loaded paper from the Manual Feed Slot.
Dec 14, 2010 | Canon LASER SHOT LBP 3300 Printer
A piece of paper is stuck inside. I tried to pull it out from the paper tray end but it has now receeded and I cant print or get it out, any ideas?This occurred when I stopped the print run mid- print by...
Just open the front door and take out he toner/drum cartridge, remove the paper cassette, best is to pull the paper forward toward the inside of printer, if none is visible you can push an index card up from the front to push out any scraps.
Feb 01, 2010 | Brother HL-5240 Laser Printer
Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Jun 02, 2009 | Canon PIXMA MP620 All-In-One InkJet...
KM 3050
All fax settings are stored on the fax eeprom memory i think, so removing it should not change any settings.
Try this (from the manual)
1 Press the System Menu key.
2 Press [FAX/i-FAX], [Next] of Reception, [Next] of Basic and then [Change]
of Multi Purpose Tray.
3 Select either [Off]
(not to use) or [On]
(to use).
4 Press [OK].
5 To exit from this setup, press [Close] several times until the System Menu
default screen is displayed.
Apr 08, 2008 | Office Equipment & Supplies
How to connect my jvc mini dv camcorder to my computer without the disc
you have not mentioned which model JVC camera you have bought, any ways, if it has with both memory card and minidv cassette facility, then you require a fire wire card to transfer cassette contents, and for stills on card insert the card to the slot and then connect it to the computer through USB cable, then the computer will recognise your camera.
Aug 11, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Canon PIXMA MX850 multifunction InkJet Printer Logo
110 people viewed this question
old marine
old marine
