Question about Cell Phones
Uncaught exception application net rim bb qm peer 367
5 Suggested Answers
SOURCE: I have an unlocked BB.
Hiqi baterine
Posted on Nov 17, 2010
SOURCE: uncaught exception 11>=11 bb
my phone went dead last night went i was in bed and when ive woke up this mornin ive put it on charge and the screen was white and said app error 523 reset so i reset it and it says uncaught exception:11 >11 and then went i press ok it just goes straight back to app error 523 .... and i need my phone :( how can i fix it without sending it off and paying for it?
Posted on Jan 06, 2011
  • 7993 Answers
SOURCE: uncaught exception application net_rim_bb is not responding process terminated
It means that some instruction was executed that led to some unforseen behavior, and that the program did not know what to do next so that it terminated itself.
You must have done something you should not have done or there is a bug in the application.
Posted on Mar 08, 2012
firesnake09
  • 2923 Answers
SOURCE: bb 9530 uncaught exception 7=7
To fix this problem, you need to either "wipe" or reset your BB to factory settings. Unfortunately, all data will be deleted. You need to back up your data to your home computer. You may follow the steps below:
1) Make sure you have Blackberry Desktop Manager installed.
http://na.blackberry.com/eng/services/desktop/
2) On your PC, go to Start > Run and copy and paste the following line exactly (meaning with the quotation marks):
"c:\program files\common files\research in motion\apploader\loader.exe" /nojvm
3) The Application Loader Wizard will appear -- click "Next."
4) In the "Connection:" drop-down menu, you should see "USB-PIN: UNKNOWN". Click the "Next" button.
5) You should then see a list of applications ready to be installed for your Blackberry. Hit Next and Finish and you are well on your way to getting your Blackberry back to life. Congrats! Just don't disconnect anything and let the lengthy process finish completely.
NOTE: If you do not see a list of applications mentioned in step 5 and instead see the message "The Blackberry Desktop Software does not have Blackberry Device Software for the device that you have connected to the computer. Contact your wireless service provider or system administrator," then you must download Blackberry's Operating System for your carrier and device.
http://www.blackberryfaq.com/index.php/BlackBerry_Operating_System_Downloads
Just select the appropriate carrier and network type, select your Blackberry model from the list and download the latest version. Install this download and follow the above steps again and you should be on the right path.
Regards,
Firesnake
Posted on Jun 21, 2012
Hi there, I hope someone can assist me with this
Sometimes it helps to upgrade your OS ...from say (a)4.2.0.442 to say (b)5.0.0.1015. I was getting tons of uncaught applications on my 9550.I upgraded from (a) to (b) and the problem is gone.Along with battery issues.Can you try that?Your carrier must have OS upgrades for your device on their website.Good luck!
Aug 15, 2013 | RIM BlackBerry 7100G Smartphone
Uncaught exception: index 13>=13 app
How To Reload Your Operating System
Here is a KB that discusses that error:
  • KB16471 BlackBerry Desktop Software prompts that an Internet connection is required to configure synchronization
Hopefully it contains something useful!
As an alternate method, from a PC, you can install any OS package to a BB via this procedure:
Note that while written for "reload" and the Storm, it can be used to upgrade, downgrade, or reload any BB device model -- it all depends on the OS package you download and install to your PC. You can even use a different carriers OS package by simply inserting, between steps 1 and 2, the deletion, on your PC, of a file named VENDOR.XML. Be sure that you remove, from your PC, any other BB device OS packages as having more than one installed to the PC can cause conflicts with this procedure.
If you are on MAC, you are limited to only your carriers sanctioned OS packages...but can still use any levels that they currently sanction. See this procedure:
  • KB19915How to perform a clean reload of BlackBerry smartphone application software using BlackBerry Desktop Software
Apr 08, 2011 | RIM BlackBerry Curve 8520 Smartphone
Uncaught exception 11>=11 bb
Nov 30, 2010 | RIM BlackBerry Storm 9530 Smartphone
Uncaught java.null. exception every time mention after I reboot my bold 9700
Can you use the BlackBerry, or is it locked up? It sounds like an application error -- did you just download or install a new application or game? If so, uninstall it and see if the error message goes away.
You can also try clearing your Java cache and all temporary files to see if that clears it up. Have you tried a battery pull?
Oct 26, 2010 | RIM BlackBerry Bold 9700 Smartphone
BB messenger error "Uncaught Exception: java.lang.null...
When attempting to send messages from the BlackBerry device, the BlackBerry device user receives the following Java error called uncaught exception java.lang.illegal argument exception:
To over come this error you need to complete the following steps:
First, perform a full backup of the BlackBerry device data:
  1. Connect the BlackBerry device to the computer using the USB cable.
  2. Open BlackBerry Desktop Manager, and then double-click Backup and Restore.
  3. Click Backup.
  4. Save the backup file.
Run the application loader tool and erase all data on the BlackBerry device:
  1. In BlackBerry Desktop Manager, double-click Application Loader.
  2. Click Next.
  3. On the Device Security Password screen, type the BlackBerry device security password, and then click Next.
  4. On the Device Application Selection screen, click Next.
  5. On the Completing the Application Loader Wizard screen, click Advanced. The Device Data Preservation screen is displayed.
  6. Select the Erase all application data check box, and then click Next.
  7. Select Do not automatically back up and restore the device application data during the loading process, and then click Next.
  8. Click Finish. The BlackBerry device resets. This might take several minutes.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 20, 2009 | RIM BlackBerry 8800
Uncaught exception
Reload your application software. https://cingular.atgnow.com/cng/tutorials/KB669.html That article will assist you. If you have any personal information you want to keep, I recommend doing a backup of your device first.
Jul 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry bold says uncaught exception: index 4+4
Reload the OS of your BB Decice connecting to Desktop Manager.
Jul 07, 2009 | RIM BlackBerry Bold 9000 Smartphone
Blackberry 8300
you should delete that and us just the msger or bbm on the phone maybe that particular software is not compatible with the BB OS.
Nov 10, 2008 | RIM BlackBerry 8800
Cell Phones Logo
14 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
