SOURCE: used toner bottle full on a ricoh aficio 400
The sensor
is dirty or damaged cleans or replaces. This is not reset.
SOURCE: the copier had started with
Your fuser and drum and toner hopper unit needs to be rebuilt/replaced. approx $1200 job.
SOURCE: I have a aficio mp
The wast toner is placed next (next) to the first tray.
To reach there open the front door and you will see a screw (placed on top toward the main swith).
After unscrew you will be able to open a small door that hides the waste toner bottle.
Be careful because it is a little messy.
Good luke. If you need extra help reply to me
SOURCE: Ricoh MP 2851 has toner
Hello!
I believe that you closed all the doors properly...
Well, this may happen because off several things.
I can give you some tips (by steps):
- First you have to make sure that the toner bottle spins (if that doenst happen it could be a faulty clutch).
- Than you need to see if the tonner supply (the green handel that you place the toner) are good.
- After that you just have the TD sensor. This sensor is on the Developement Unit.
Well, i am just giving you a clue. If you do not have thecnical knoledge i advise you to call your provider.
See you, And good luck
The copier uses a photo sensor to determine when to replace the bottle. If the inside of the bottle is covered with toner, it thinks the bottle is still full. There should be a projection on the back of the bottle that fits into the sensor. You can try to clean the inside of the projection, but don't use any kind of liquid, use a dry cloth. You may have to buy another bottle. New ones should come with the toner. dood luck.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
