Question about Frigidaire FRS26R4A Side by Side Refrigerator
Power surges in area now it wont frezze and barely cools down on food side
Poer surges in local service area --frezzer wont frezze and food side only cools slightly thinking an electric blowermotor or a compresser was taken out due to low voltage condition are there any tests to isolate the problem or ? HELP PLEASE
  • Anonymous Mar 16, 2014
    Fridge side frezzing up foods
WELL IT SURE WASNT THRU YOU GUYS AND YOU SO CALLED FREE ADVICE SECTION --- ITS ALWAYS ABOUT THE FUCKIN MONEY ----HAVE A GREAT DAY
Posted on May 18, 2009
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
I have a GE artica md417876 ps525mgna ww side by side the frezzer is not frezzing the food it sounds like the fan is working what can I do to fix this problem
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 25, 2011 | GE Profile Arctica 25.4 Cubic Feet...
GE refrigerator model # PSS25MGNAWW. Food compartment was frezzing I replaced the damper the old damper had a broken door. Now the unit will not cool in frezzer or food compartment. I unpluged to allow it...
Unfortunately this problem crops up many times....seems that if the system maintains the status quo it is fine, but when you unplug it for any amount of time it upset the equalibrium of the system and it is difficult to get it back...
The best thing is to be patient....
Unplugg the system again and let it set for an hour or two....then try again...
Sometimes you just need to let it plugged in for a few days till it will start working again...
Seems as though there is no set way to get each and everyone going...so experiment and keep trying and you will eventually get it working...
I could go into all the intricate deatials about what has happened. but it will not help you and would just confuse most people...
heatman101
Feb 19, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
ALL THE SUDDEN FREZZER WILL NOT GET COLD ENOUGH TO FREZZE POP SICALES BUT IT STILL WILL MAKE ICE ANE ITS BARELY IS KEEPING THING S FROZEN. THE REFRIGATOR PART WORKS GREAT CAN YOU GIVE ME SOME SUGGESTIONS
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Nov 19, 2010 | Kenmore 56239 / 56232 / 56234 / 56236 Side...
My refrigerator stopped cooling.But my frezzer still works.
check the fan that runs between the freezer and fridge section [usual access is from the freezer side] if fan not working check thermostat is set at coldest in fridge then check for power to fan if power check for blockage from ice, food.etc if clear check damper inside housing is open and working properly---the fridge is cooled down from the freezer via the fan
Jul 26, 2010 | Frigidaire Refrigerators
Refrig/freezer not cooling/freezing
your gonna have to let thr fridge defrost buy shutting it down because it soundsm like you have either a build up of ice it the vents in the back of the frezzer unit also check to see if you can hear the fan working in the frezzer if not that would be you main problem
Jul 26, 2009 | Freezers
Having temp problems
for a freezer would suggest a thermostat problem easily replaceable if you follow the removal of the old thermo.use temperature gauge to set to the required degree after instaling new thermo
May 21, 2009 | Freezers
Fridge is not cooling
You probably need an adaptive defrost control which is located in the back right hand corner of your fresh food compartment. You have to dismantle the overhead controls to get to it. If you had to defrost your coils, and the heaters test good, then you probably need the above control.
Apr 06, 2009 | Maytag MSD2454G Side by Side Refrigerator
Frezzing
It can take up to 24 hours to chill the interior cabinet and contents.
Apr 04, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
New Sanyo Fridge not working
I have the sam eproblem but my freezer is very cool, but the fridge wont get cold, it is just chilled, my food still goes bad and the water and soda is room tem..this doesnt make sense!
Nov 25, 2007 | Sanyo SR-1030W Top Freezer Refrigerator
Frigidaire FRS26R4A Side by Side Refrigerator Logo
139 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
