Question about Water Heaters
Superflue water heater green light on
I've unplugged then re-plug the gas water heater. It starts then stops 2-3 times, like a reboot, tries to cycle then the 3 yellow temp lights come on followed by a green light, and it stops. Above the green light the word vacation is marked.
muttandjeff
  • 359 Answers
SOURCE: rheem water heater pilot light goes out
REPLACING THE SPARK IGNITOR WOULD BE MY FIRST GUESS .
Posted on Feb 23, 2009
  • 659 Answers
SOURCE: How to install a new temp sensor Whirlpool electric water heater
The instructions for installing the sensor will probably included with the new part. Also, when you receive the part and actually see it, you will probably know where it will go. Sometimes, things like this happen even with new units. I have had bad thermocouples on brand new units right from the factory. It happens and unfortunately it happens to us sometimes. Good luck and if you get the part and still have trouble, contact them again. If you would have bought a GE (Rheem) unit, they would have sent a tech out to your house at no cost. I'm not a fan of Whirlpool water heaters.
Posted on Apr 02, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: pilot light won't stay lit after release of gas valve.tried few t
Most likely it's time to replace the thermocouple, the safety device that makes sure the pilot is lit. New thermocouples are cheap and you can find them at most hardware stores and the big-box places (Home Depot, etc.)
Here is a site with basic information to get you going.
Posted on Apr 08, 2009
gary1121
  • 332 Answers
SOURCE: Rheem 40 gal power vent gas water heater shows code 42
you plugged it in and the fan started or you unplugged it and the fan started,,the fan will come on first before the unit will inginte to take out the excess gas, if it didn't lite then the ignitor might not be working there are 2 swithces on the unit one on the fan and one by the gas valve make sure they are both on and make sure the gas it also turned on.
Posted on May 30, 2009
heatman101
  • 43501 Answers
SOURCE: My Superflue water heater is flashing Eco failure.
The ECO is short for emergency cut off.
The ECO is either tripped or it went bad. You may be able to reset it or you will have to contact a rep the sells your heater to get a new part. Some are resetable and some are not... not sure which you may have. The reset ones will have a little red button to push in the center.
The next rpoblem is to figure why the ECO went or tripprd in the first place. There is probably a reason or a cause. When you refire it make surte you donot have flame roll out and proper venting. Also make sure the the thermostat works and is not letting it get too hot.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 08, 2009
Superflue. Why doesn't it stay lit?
If this is in a RV there is a propane monitoring valve. It will close and cut of the propane if it is not being used for a period of time or if there is a leak. The valve is mounted between the propane tank and the first appliance, usually inside the RV.
Mar 09, 2016 | Water Water Heaters
Rheem model 41vrp40n flashes twice and stops working
Error code means that you have electronic gas control valve.
Copy following link to identify gas control valve, read error code meanings for each, and download service manual relevant to each gas control, but not specifically Rheem since rheem does not post service manuals.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
The fact that water heater restarts, means that water heater is getting gas, getting sufficient air for combustion, thermister is ok, gas pressure is good, etc.
The fact that you unplug and replug water heater and it works, shows that you have power vent model.
Since water heater worked correctly before, 2 flashes with Rheem power vent model could mean that pressure switch has failed.
Jul 29, 2012 | Water Heaters
Cant restart gas heater it atempts to light three times then red light comes on and vent stops
Your brand and model number are not known, nor is type of gas control valve. Location of water heater, recent events, age and other factors are also unknown.
Copy following links for possible troubleshoot resources, including troubleshoot by type of gas control valve:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Jul 17, 2012 | Fasco GSW Hot Water Heater Exhaust Draft...
FVD interface failure is flashing. How do I reset the water heater?
Is it flashing 2-3? Try this: You can reset the control by unplugging the blower during start up, leave unplugged for at least 5 seconds, plug back in and within 30 seconds cycle temp control from hot to low 6 times.
Nov 06, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
No power at all to my superflue water heater
Hi, first check and try and reset the breaker feeding the water heater. That should be a two pole breaker. The next thing to check is the red safety button on the top thermostat control. It is under the top access panel of the heater, along with a good amount of insulation. Push the red button to reset the safety switch. If these do not remedy your situation, then you will need someone on site to check the water heater in more detail.
Apr 05, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Superflue heater will not light
The self igniter, or thermal couple is bad.
Mar 27, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
My Superflue water heater is flashing Eco failure. What is this? What do I do?
Heatman101
Dec 08, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
May 30, 2009 | Water Heaters
Water Heaters Logo
74 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
