Question about HP Pavilion F1703 17" LCD Monitor
Stuck in "sleep mode"
I recently unhooked my entire PC. When putting everything back together I started to have a problem with my monitor. The monitor seems to be getting power but says "monitor going to sleep" and then shuts itself off. Did I hook something up wrong?
  • 1 more comment
  • purple42 Jan 17, 2008
    I turned my monitor off, then when i turned it back on it says monitor going into sleep mode and the light turns yellow. I've tried F8 but nothing happens, I've tried right clicking but also nothing, I've unplugged everything and turned everything off/on but no results. Any ideas??????
    Thanks
  • morganbarber Mar 05, 2008
    I have the same problem. The computer seems stuck in sleep mode. If I disconnect the monitor cable, monitor says "check connection", otherwise, it just says "going to sleep" and goes to amber. When started, the fan runs and lights come on, but I don't think it boots. "number lock" and other such lights on keyboard won't come on.
  • mgrieder Oct 08, 2008
    I moved my HP Pavillion M7750N Media Center and can't wake the 22 inch HP monitor up at all.... I had this problem when I first bought the computer about a year ago - however, it would turn on when booted then, but if I left the computer alone for more than 10 minutes, it was in permanent sleep mode.... I've relocated and set it back up, and the monitor says no input signal then goes to sleep - I can't do anything with drivers, etc., because I can't access the computer at all - I've tried holding the source button and get "monitor going to sleep" icon.... any suggestions? Thanks.
    Sergeant:
  • 349 Answers
A possible fix would be to go into the bios and select "standard settings" or something close to that statement,then re-boot the system
hope this will help
good luck
Terry
Posted on Mar 10, 2008
SOURCE:
When I try to bring my LCD monitor out of sleep it just comes up a dim lighted screen and cannot see desk top. I put my PC in sleep mode then wake it back up and monitor is perfectly fine? how can I
I suspect the monitor. For the sake of troubleshooting: Try another monitor for a few days. If you have the same issue, we will know it is the video card.
Sep 16, 2014 | Computers & Internet
Computer will not start after going into sleep mode
Shut pc down unplug power supply press and hold power button for 20 seconds to remove all remaning power.open case clean any dust find ram sticks remove them make sure there clean and re seat them back into there slots.your monitor could be the cause also unhook it while pc is unplugged. now put it all back together and turn it on..if it doesnt shut it down un hook monitor and fire up pc see if the pc boots by watching the lights.if so bad monitor does light turn blue on monitor when power on.
Mar 16, 2012 | Computers & Internet
When i turn on it goes start to pc entering power saving mode
Are you sure it isn't the monitor entering powersave mode?
An unhooked monitor (especially flatscreen DELLs ) will go into powersave mode if it isn't getting a signal but is getting power.
First unplug and then replug your monitor. Both ends of the cord, the end in the back of the monitor (if it comes out at all) and the end that plugs into the computer.(unplug it from the wall first)
Reboot computer.
If that fails...(and you do have a video card)
Unplug everything from the computer, open the box, ground yourself by touching the metal frame of the computer case and reseat your video card....you may have to undo one screw to get it out.
DON'T drop the screw into the case!
Put it all back together and try again.
If that all fails Boot Windows (windows right?) into safe mode and change the power settings for the monitor...perhaps something got changed or broken by an update.
If that fails....
Get Linux.
TickMagnet
Aug 17, 2011 | Gateway 505GR PC Desktop
The monitor starts up and goes into sleep mode
After repairing the on/off button for $100.00 and then rehooking up the monitor to my pc, the monitor has power but stays asleep even when I push in the menu button, I can't get anything to happen. HP techs tell me that the problem is with my computer although it worked perfectly fine before I unhooked all to send out the monitor.
I hooked all back up again as before but now the monitor will only say "monitor going to sleep" and nothing happens.
Wishing I had a solution. Thanks
Sep 10, 2010 | HP f2105 21" LCD Monitor
My new L1940T (hp) monitor is stuck in sleep mode. At boot, green light illuminates, then goes orange. Window opens saying 'going to sleep mode' then completely unresponsive. Tried everything; moving and...
We need to narrow down to find out if it is your PC is not sending the video signal to the monitor or the monitor itself is bad, you need to try this monitor with another PC or try this PC with another monitor. Please post back what you find after trying the suggestions.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-bidi-font-size: 12.0pt"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-bidi-font-size: 12.0pt"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span><br />
Aug 26, 2010 | HP L1940T 19" LCD Monitor
Compaq Presario stuck in sleep mode
Connect the monitor to some other computer, e.g., a notebook, and see if it does the same thing. If it does, then the monitor is the problem.
If it does not, then your computer is not putting-out any "video" signal, and so the monitor goes to "sleep".
If you have MORE than one VGA-output port on your computer, connect your monitor to the "other" VGA port.
Or, press-and-hold the ON/OFF button on your computer, to force it to completely shutdown.
Jan 13, 2010 | HP Pavilion a1710n (RK573AA#ABA) PC...
Hp computer monitor
Hey, the problem you are getting is caused by the pc, when you switch on the pc it sends a signal from the graphics card to the monitor to come off sleep mode and display a picture,
it could be the graphics card, or memory or something more serious,
would try taking out the graphics card and memory and putting them back in see if the machine starts up.. works most of the time..
All the best
John
Jul 26, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
My desktop pc has gone into power save mode
Turn the whole pc off then back on. If the LCD stays in power save then I would try a diffrent monitor on the PC. If that fixes it the the monitor is probably stuck in power save. Check www.lcdrpair.us for parts and instructions.
May 28, 2008 | Dell E173FP 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
301 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
