Question about Aiwa PX-E860 Turntable
How do I remove a stylus from a Aiwa pxe80k
We can't remove the stylus
How do i change a stylus on aiwa PXE88
Hi, Grip the stylus between your thumb and forefinger. Pull the stylus down toward the front. As it comes loose replace the downward motion with a forward one. When fitting new stylus insert the tongue of the stylus into the groove in cartridge. Push it backward into place and then upward. John. Stylus City.
Nov 29, 2014 | Aiwa Audio Players & Recorders
How to replace stylus on AIWA stereo turtable
the old stylus snaps off. pull evenly straight out. The new one snaps on in its place. Do not touch the needle as it is easily damaged.
Jul 02, 2014 | Aiwa PX-E860 Turntable
How do I remove the stylus of an Aiwa PX-E850 Turntable?
Hi, grip the stylus between thumb and forefinger. Then in a pulling down and forward motion remove stylus. Cheers john. Stylus City
Apr 02, 2014 | Aiwa PX-E860 Turntable
Stylus
All you need to do is look at the cartridge which should have a number. Put that into Google and the stylus should appear.
Jun 24, 2013 | Aiwa PX-E860 Turntable
I need a stylus for a aiwa PX-E86OU
http://www.lptunes.com/Aiwa-turntable-stylus-s/215.htm
Dec 02, 2012 | Audio Players & Recorders
On my Aiwa PX-E860 the automatic mechanism is failing - when i thry to manually place the stylus the platter does not turn - is there a way to by pass the automatic part and just have it manual?
Select the record speed.
Press the 2 down arrows or triangles( placed side by side) - This the same thing you press if you want the styles to lift during play
Place the stylus on the desired spot.
Press the same button again.
The stylus will drop to the desired spot & continue playing
If you have the manual look it up, else download one from this site after becoming a member(its free)
http://www.retrevo.com/support/Aiwa-PX-E860-Turntables-manual/id/1077bh126/t/2/
Nov 30, 2010 | Aiwa PX-E860 Turntable
How do i remove the stylus from aiwa px/e850
Hi, grip it at the front edge and pull downward then forward. styluscity@gmail.com
Sep 09, 2010 | Aiwa PX-E860 Turntable
I need a motor for my aiwa px-e 860 turntable
Hi, stylus city can supply a motor for this turntable. Styluscity@gmail.com
Jun 23, 2010 | Aiwa PX-E860 Turntable
Turntable with no stylus
Provided the replacement stylus is the correct one for the cartridge you have, it should just slide in from the front of the tone arm into the cartridge.
Jan 18, 2009 | Aiwa PX-E860 Turntable
Aiwa PX-E860 Turntable Logo
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
