Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
Ice from ice maker smells and taste bad - GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
We have a similar fridge: part of the issue could be with the filter, GE has a 6 month filter and a 1 year filter. Might be time to change it (I believe the MWF filter is one year, the GWF is 6 months). Changing the filter helped in our case.
But overall, if you leave lots of leftovers in the fridge, the ice will pick up the smell. A couple of boxes of baking soda should help absorb the smell before it settles itself in the ice.
Posted on May 17, 2009
My maytag fridgee has a metalic smell which has made all my food in both fridge and freezer taste bad
IF you have an automatic ice maker, the electrical connection in that is bad, you need to replace the ice maker or disconnect it and remove it.
Jul 23, 2016 | Maytag Refrigerators
Bad fan blower smell and bad smelling and tasting ice cubes from ice cube maker
If unit has a water dispenser, how does water taste? I've run across bell peppers that will emit a bad smell. Keep in mind 95% of all refrigerators circulate air from freezer to refrigerator side and then back. It continues to circulate air so bad produce from refrigerator side will get into freezer side and ice will absorb smell. First, dump all ice. Then line shelves in refrigerator side with newspaper, that absorb smells. You can even try kitty litter in small cups in refrigerator side. Bell peppers gives off that metallic smell and can take some time to get out of unit. Highly unlikely a motor is bad and you've already changed outside water line.
Aug 07, 2015 | Maytag Refrigerators
Why does the ice in my freezer taste and smell bad even though I changed the filter?
OLD PIPES NEED REPLACING,OR DID HOUSE WATER LINES SET A WHILE ,HOW LONG DID ICE MAKER NOT BE USED .CAN YOU REMOVE ICE MAKER AND CLEAN?. MOLD MAY OF ESTABLISHED OR RUST.TAKE WATER LINE OFF BACK THIS IS EASIEST. AND RUN 5 GALLONS OF WATER IN A BUCKET.TEST WITH A CLEAR GLASS WITH SOME FROM THE FLUSHING OUT WATER.IF IT DOES NOT CLEAR UP,HAS THE WATER COMPANY RAN TEST ON THEIR PRODUCT.THEIR MIXTURE OF FLUORIDE AND SUCH MAYBE FUNKY.DOES WATER LOOK CLEAN.GET CLEAR GLASS,FILL WITH ICE AFTER IT MELTS SEE IF THINGS AT ALL ARE FLOATING.DO SAME TEST AFTER YOU RUN 5 GALLONS OF WATER OUT OF THE LINE.ICE,MELT LOOK.HOW DOES WATER TASTE OUT OF DOOR IF THAT TYPE.IT CONFIRMS WATER LINE OR OUT OF FLUSHING WATER.IF IT TASTE OK FROM FLUSHING WATER THE SOURCE IS AS DESCRIBED IN THE FIX...
Jul 25, 2014 | Whirlpool Refrigerators
Ice maker water taste like chlorine but tap tastes fine
Put a in-line water filter on the water line if you want. The taste is from the food and items you have in the refrigerator. Clean it out and keep your items in proper storage. Ice collects the smells in the line and the fridge. Change your ice that is sitting in the bin, wask out the bin with water and baking soda. Hope this helps.
Apr 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker has bad taste and smell
Add a cap of Miltons or a couple of granules of pool chlorine. Allow it to stand for a couple of hours and then drain.
Mar 08, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Bad tasting water and ice from refridgerator.
i agree with rpbuice but in addition to flushing the water line you may need to replace the line then using the water dispencer run out about a gallon of water thru the door. this will clear the reservoir of bad tasting water. for the i/m throw out all of your ice then let it make a couple of batches and throw out that ice as well be sure to clean your ice bucket very good to remove any lingering tastes from the old ice.
fyi bad tasting water is generally from bad water supplies. good luck..
Jan 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker problem
let it run its caused by stagment water in the system it will clear over time.
Feb 09, 2008 | Refrigerators
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
188 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
