Question about Craftsman Garden
36" Craftsman riding mower. Turns over, getting fuel and spark but will not fire and start up. Originally started went about 25 ft cut off and will not fire back up. New plug & fuel filter install
36" Craftsman w/11HP Briggs & Straton Engine riding mower. Originally started went about 25 ft cut off and will not fire back up. Turns over, getting fuel and spark but will not fire and start up. New plug & fuel filter installed, Air filter cleaned. Grime build up around selonoid & magnet wheel found, cleaned off. Put in new plug got one back fire and nothing further. Cut off switch quit working years ago and has been disconnected ever since. Out of ideas????
  • 1 more comment
  • Anonymous Mar 31, 2014
    have fuel and spark compresion ok posible timing issue check valve timing ok single cyl motor want to know ignition timing were magnets will fire coil in relation to coil contacts
  • tom smith
    tom smith Aug 10, 2014
    i replaced spark plug and gas filter but it back fires and does not start
  • tom smith
    what can i do?
  • 61 Answers
If anti back fire selonoid is disconnected how
are you getting fuel? if so ck selonoid again make sure it is open. should run
Posted on Sep 07, 2009
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
Lawn mower will not start,but turns over...how do I find a fix?
Remove air filter and pour a small amount of gas directly into the carb. Try syarting. If it runs then dies off you either need a carb rebuild or you have no fuel getting to the carb. Please be careful as if it backfires the fuel can catch fire. It only takes a very small amount...a teaspoon or so for this test.
Aug 01, 2016 | Craftsman Garden
Craftsman LTS 1500 lawn mower - model # 917.28903 started sounding funny while i was cutting VERY high grass. I turned it off immediately and it backfired as it shut off. Wouldn't restart. Waited til next...
I would check the big three first of all. Spark, compression and fuel. Sounds like you have spark and fuel. I would get a compression tester to check actual amount of compression. If all three of those things are good I would check valve lash. You will need make, model and serial number of engine. If you post these I can help find specs for you. Good luck.
Sep 14, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower turns over but won't start
unplug the connector from the side of the engine and try it if it fires on starting fluid then the problem is one of the safety switches
Apr 22, 2012 | Craftsman Garden
Craftsman 17hp 42" cut riding
Sounds like its not getting enough fuel. clean the fuel system and the carby. The valve clearances also need to be checked.
Apr 07, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Nov 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawm mower back fires and kills when blade is engaged
Check your spark plug. Or maybe your choke is stuck
Jun 19, 2009 | Craftsman Garden
Garden Logo
397 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
