Question about Altec Lansing VS4121 Speaker
Want to know if altec vs3251 is for 110 or 220 volts
    Sergeant:
  • 229 Answers
My source of pdf manual seems to indicate 110
Posted on Jan 03, 2015
Altec lansing acs33
the subwoofer plugs into the wall on a 110 volt outlet. then use mastervolume control.. RANDY
Apr 28, 2014 | Altec Lansing Multimedia Computer Speakers
Need to know the voltage on the dc power adapter for ACS5 model
Hard to find info. It looks like they run on about 14 to 15 volts dc. It's not critical. Check local electronic surplus stores or thrift stores before spending a lot more elsewhere.
Oct 06, 2010 | Altec Lansing Multimedia Computer Speakers
Ac adapter for altec lansing model#acs40 voltage,current & polarity
Altec Lansing Model Number A 1664
Output 15 volts DC 800ma
center Positive +
Jul 29, 2010 | Altec Lansing Multimedia Computer Speakers
I plugged my 110 volts Altec Lansing speakers into 220 volts :( How can I fix it? Please help me. Thank You.
Check fuse, but if there wasn't a fuse , your Altec need repaired to fix broken components in power circuits, could be the resistors, diodes or even transformer.
Jul 03, 2010 | Altec Lansing BX1020 Computer Speakers
Step up transformer for altec lansing atp3 that runs on 220 volts
What voltage are you stepping up to?
Does the unit run off a seperate PSU/Transformer.
Can you check your info please.
Jan 19, 2010 | Altec Lansing ATP 3W Computer Speakers
Stops working after a few minutes
this problem name is dst plz change mark dc ic is working propery
Aug 25, 2009 | Altec Lansing iMT525
What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Nov 20, 2008 | Altec Lansing AVS 300 Computer Speakers
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any...
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Oct 17, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing computer speakers model AVS500
18VDC 1000mA Center Positive.
Altec-Lansing
Part Number: AVS500-A6860
Model Number: 9701-00648-1UND
Jun 02, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing VS4121, New Speakers, No Sound
If the speakers are brand new it makes me wonder how you know they worked fine in the States? I am also wondering how they were transported due to them probably being intolerant to extremes of temperature/humidity and probably vibration.
I am also wondering if you are using the correct supply voltage and type of supply.
If you are using the power adaptor supplied for use in the USA, it would probably be incompatible with your supply even though you are using a transformer.
If you are certain the speakers are in good order I suggest you obtain a power adaptor designed for your 220 volt 50Hz supply. I have browsed a little and cannot find a note of the power requirements for the integrated amplifier but this is presumably marked on the adaptor, the speaker or in the manual and so the power adaptor could be checked on and off load with a suitable voltmeter. I would be surprised to learn the supply is adequate
Apr 01, 2017 | Altec Lansing VS4121 Speaker
Altec Lansing VS4121 Speaker Logo
96 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
