Question about Lang Manufacturing EHS-APM Electric Oven
Need instructions on how to program all ten buttons for different temperatures for we have no manual that shows us how. We manually programmed button number 1 for 350 degrees F and it works, but can'
We inherited a Lang Electric Commercial Oven in our little bakery. We figured out how to manually program the number 1 slot to 350 degrees F, but do not know how to program the other 9 slots for different temperatures. The previous owner did not leave a manual for us to be able to do this process. Can you please give us instructions on programming the individual other buttons? Thanking you in advance for your assistance in the above problem.
  • 1,250 Answers
Http://www.langworld.com/lang_cd/Operate%20Manuals/CNVTOVEN/Op%20Convections.pdf
Check out this web site for your manual. The model EHS-APM is not listed but there are other units with multiple programming options. You will have to browse somewhat but what you are looking for is probably there.
Good Luck and hope this helps.
Posted on May 23, 2009
How do I fix my programing light on my oven fix my
the programming light ???
on what model what make
this is a display ilumination ????
if so its usually a small 12V bulb or in some a led backlight
sometimes there is a button too turn it off
call an engineer in the fix it or ask a pal with electronics knowlage
as you dont seem very confident too do it leave it too someone who knows how to use a multimeter and get the right part
quite easy a service tech should charge you know more than £40
+ parts
Nov 30, 2014 | Ovens
I have a whirlpool accubake oven that is stuck on the celcius temperature and I don't have an owners manual and I need to reset it to farenheit. Please help!
To switch it to Farenheit..press and hold the BROIL button for up to ten seconds and the display of the broil temp will change from 500 to F then push clear/off button...if later on it needs to be switched back to C do the same thing
GENE
Aug 28, 2011 | Whirlpool Ovens
How do i set the time on w westinghouse pgn659s wall oven?
Instructions below.
  1. 1 Fill the insert of the Corningware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  2. 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  3. 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
thank for visit.
Oct 09, 2010 | Ovens
Oven shuts down before reaching correct temperature
You will need to check the oven calibration using a thermocouple based thermometer(the one you stick in the oven is not reliable). Electric ovens should keep a near constant tempature so if you have it set to 350 the oven should stay around 350 once temp is reached. Now gas ovens are a little different. Most use a on/off thermostat and that means the temp can vary from 320 degrees to 370 degrees to keep an average tempature of 350. So if it is a gas oven you will need to let it warm-up for 10 minutes then start taking the lowest and highest 5 consectutive readings. Then add the 5 reads together and then divide the number by 5 and it should be within 10 degrees of the set tempature. If it is off by more than 50 degrees then you might not be able to get it back to proper calibration. The calibration methods are different for each range and depend on the type of thermostat you have digital(push button controls) or manual(knob). The owner's manual for your range might contain the instructions or consult the manufacture's website for the instructions.
Dec 21, 2009 | Whirlpool Ovens
Flashing F2 warning
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 | Ovens
Programming a Lange Oven
go to partstown.com the have the manual for your oven in the top right corner
Jun 17, 2009 | Lang Manufacturing EHS-APM Electric Oven
How to set the timer
1. Set the oven to the required
temperature.
2. Press the g button.
3. Set the total cooking time with the +
button (see the example in the
illustration right, showing 1 hour and
30 minutes).
4. Press the h button.
5. Set the cooking finish time with the +
button (the example in the illustration
shows 12.30 hrs.).
After setting the display shows the
time of day and indicates »AUTO«.
The oven cooling fan will start
immediatley.
At the pre-set time, the oven will be
automatically switched ON.
The settings can be corrected at any
time.
When the pre-set cooking finish time
is reached, a signal sounds and the
oven is automatically switched OFF.
To turn the signal off, briefly press the
h button.
6. Turn the oven selector switch to the
0 position.
7. The »AUTO« symbol blinks.
Important: It must be switched OFF
by pressing the E button.
Also here is the manual.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Good Luck
Jan 20, 2009 | Neff U1721 Double circotherm Electric Oven
Beaumark stove
I also don't have a manual, but work on computers so tried some buttons and they did the trick.
On the left hand side is the button that has Mode, and then a series of buttons.
On the right hand side there is a series of buttons, and one looks like heat coming from the bottom. Turn this button to that setting.
On the left side, press the mode button, and then press the button that looks like a thermometer. This is the mode for setting the temperature of the over.
Beside the display windows, there is knob that looks like a dial on an analog clock. Turn this dial until the temperature you want appears.
Oct 23, 2007 | Ovens
Lang Manufacturing EHS-APM Electric Oven Logo
215 people viewed this question
Top Lang Manufacturing Ovens Experts
Dennis Boxerman
Pat
Pat
Level 1 Expert
Tom Chichester
Are you a Lang Manufacturing Oven Expert? Answer questions, earn points and help others
