Question about HP LaserJet 4 plus Printer
Setup a laserjet4 printer
How setup a jaserjet4 printer in windows vista,the printer is using a jetdirct J2550B,port 10 Base-T,On the AUX IO Menu you have IP Byte,Sm Byte,LG Byte,GW Byte,How do you set this up.THANKS
    Problem Solver:
  • 6 Answers
The printer might not be certified for windows vista if it is an older printer might just have to buy one that is certified for windows vista
Posted on May 17, 2009
I can't install my Brother MFC6490CW printer onto
All these three methods involve some specific code in the printer drivers both in Print server and clients.
Not all printers will have drivers that will support all 3 ways of using the printer. It appears that not all printer drivers, written for Windows Vista. If you can't get your network printer, please try the following steps to bypass the LPT redirection. 1. Install the Vista printer driver on your Windows Vista computer.
2. During installation, you'll be prompted to connect the printer to your computer. Choose the option to proceed with installation without connecting the printer.
3. After installation completes, open the Printers wizard from the Windows Vista Control Panel.
4. Right click on the entry for the new printer, and choose Properties.
5. Go to the Ports tab.
6. Click Add Port, select Local Port, then click New Port.
7. For the port name, enter the network path and share name of your printer ("\\TheirComputer\TheirPrinter1").
8. Click OK, and verify that the new port is selected.
9. Click OK to close the printer properties.
May 22, 2011 | Acer Computers & Internet
How do I install Konica Minolta Bizhub C350 copier using a router and 1 computer with Vista 32-bit?
To setup LPR Printing, perform the following:
For Windows 2000/XP/Server 2003:
1. For Windows 2000, click the [Start] button, point to Settings, and then click Printers.
2. For Windows XP/Server 2003, click the [Start] button, and then click Printers and Faxes.
3. Right-click the icon of the installed printer, and then click Properties.
4. On the Ports tab, click the [Add Port] button.
5. In the Available Printer Ports list, select Standard TCP/IP Port, and then click the [New Port] button.
6. When the Add Standard TCP/IP Printer Port Wizard starts up, click the [Next] button.
7. In the Name of printer or IP address box, enter the IP address for this machine, and then click the [Next] button.
8. Select Custom, and then click the [Settings] button.
9. Select LPR, enter Print in the Queue Name box, and then click the [OK] button.
10. Click the [Next] button, and then click the [Finish] button to apply the setting.
Oct 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Windows says printer offline, but it is not offline. network settings confirmed. windows firewall turned off. scanner works perfectly over network, but printer is "offline"
The printer offline error mostly troubles windows 7/8/10 users, The printers loses connectivity even when it is connected and operating. The status message displays offline on the computer, and the printer does not print. An Offline status indicates that the computer has failed to communicate with the printer. In some network conditions, the printer might get offline unexpectedly.
Before going to the solution for this you must know when and why printer offline error takes place:
The error may appear when Windows 8 diagnoses that the printer is unavailable, but unfortunately, most times it fails to tell whether the printer is really offline or if it has connectivity problems or printing errors. Reasons why your printer appears to be offline, include problems with hardware, such as disconnected cables or malfunctioning equipment, and problems with software, such as corrupted or incompatible driver files.
These might occur when:
1. The connection between the computer and the printer is slow/unresponsive.
2. The printer has encountered an internal error
3. There are multiple unfinished print jobs in the queue.
There are some simple steps you can follow before going to any complicated way:
Your printer offline can be a problem with the driver software. This is a small piece of code that Windows and the printers use to "talk" to each other. If the driver software is outdated, corrupted or incompatible with the version of Windows that you have installed, you may need to update it.
Restart the printer and the computer or unplug its USB cable.
Do check that the printer's power cable is plugged into an electrical outlet. If the printer is connected to a power strip, make sure the strip itself is connected to the electricity supply and is turned on.
In case you are using a network printer both wired or wireless, You restart the router as it may cause due to network failure.
Different manufacturers come with their own diagnostics software which can inform the user about the problems coming up (Ex : HP's Print and Scan Doctor), Use it as it will be really useful.
PRINTER OFFLINE ERROR Solution 1 :
Type in Services in your windows searches and hit the enter key. Click on Services option from the set of search results as shown below.
A new window for Services opens up. Scroll down and find the entry named Print Spooler.
Now right-click on Print Spooler entry and then on Properties option.
Set Startup type as Automatic from the drop-down menu.
As next, hit the Start button and wait till windows start the Print Spooler. Once done, hit Apply button.
Now if you look at the status of the Print Spooler, you can see that it is Started.
Solution 2 :
If the above method doesn't work for you, you can always try our second method. For that, type in Devices to the windows search and choose Devices and Printers from the search results.
Now find the printer that is offline and right click on it. Click on the option See what's printing from the context menu that appears.
A new window opens. Now click on the Printer tab and uncheck the option that says Use Printer Offline.
Aug 04, 2009 | Canon PIXMA MX850 Multifunction Printer
On linux centos it doesn work
The CT4170 SoundBlaster "Vibra" cards are old 16-bit ISA PnP cards, and were not detected at install by Linux kernels 2.16.15-27. You need to get the "isapnptools" package from the Fedora or CentOS sites, and do the following:
2. Install isapnptools using dpkg -i path-to-downloaded file .
3. Create and edit file /etc/isapnp.conf and put the following contents in it:
(READPORT 0x0273)
(ISOLATE PRESERVE)
(IDENTIFY *)
(VERBOSITY 2)
(CONFLICT (IO FATAL)(IRQ FATAL)(DMA FATAL)(MEM FATAL)) # or WARNING (CONFIGURE CTL00f4/-1 (LD 0
(INT 0 (IRQ 5 (MODE +E)))
(DMA 0 (CHANNEL 0))
(DMA 1 (CHANNEL 1))
(IO 0 (SIZE 16) (BASE 0x0240))
(IO 1 (SIZE 2) (BASE 0x0300))
(IO 2 (SIZE 4) (BASE 0x0388))
(NAME "CTL00f4/-1[0]{Audio }")
(ACT Y)
(WAITFORKEY)
4. Run "isapnp /etc/isapnp.conf". If it reports errors, you must change configuration above (it is suited to my setup). Try "pnpdump -c" and put its output in /etc/isapnp.conf file. If it does not help, you must find the correct configuration manually, for example change port to 0x220. For full list of possible values run pnpdump. Note that if you change the configuration, you must change options for modprobe below.
5. Create and edit file /etc/modprobe.d/sbvibra and put the following options in it:
alias snd-card-0 snd_sb16
options snd_sb16 port=0x240 irq=5 dma8=0 dma16=1 isapnp=0
6. Run "update-modules"
7. Run "modprobe snd-card-0". If it works OK (check if "ls -l /dev/dsp" shows that file is present), perform the steps below to make setup permanent:
8. Append following line to /etc/modules:
snd-card-0
8. Go to system configuration (in GUI) and choose "Services". Enable "isapnp" service and tick option to start it at boot.
Hope this helps :)
Ted
May 23, 2009 | Creative Labs CT4170 Sound Card
Unable to install DP G 301 For laser jet 5 printer
0.Follow the manual instructions to configure the Printer Server (tpc/ip), connection toyour local wireless LAN, etc. then, specific for Vista: 1.Vista Start Button 2.Control Panel 3.Printer 4.Add New Printer 5.Select Local Printer 6.Click on "Create new Local Port" and from the menu "Standard TCP/IP Port" 7.Click on "Next" button 8.Menu "Type" select TCP/IP and write the IP address of your Printer Server. UNSELECT "detect printer to..." then press "Next" button 9.If everithing is fine, it must find your printer server. 10.Select your driver ... that's it .... unfortunately I found some problems printing documents: it works till half page then the printer stop and I must cancel manually from the printer the job in order to reset the printer itself.... looking for solutions
Mar 16, 2009 | D-Link Computers & Internet
Usb connection not known / printer not connected
Solution: Uninstall / reinstall the printer driver (Windows) PIXMA Printers
Uninstall and Reinstall the Printer Driver (Windows) Follow the steps below to uninstall the printer driver:
  1. Select 'Programs' or 'All Programs' from the Start menu.
  2. Select the Canon printer driver you want to uninstall, and then select 'Uninstall' from the menu that appears.
    Note: Click here if your printer does not appear in the Windows 2000, Windows XP or Windows Vista Programs menu.
  3. When the confirmation message shown below is displayed, click 'OK'.
  4. A window showing the progress of the un-installation is displayed. Wait until the "Uninstall successfully completed" message is displayed, and then click 'OK'.
    Note: If you use Add or Remove Programs to uninstall the printer driver, the printer model name will remain in the Start menu. To completely remove all files, including the printer model name from the Start menu, uninstall the printer driver using the procedure described in step 2.
In Windows Vista, Window XP or Windows 2000, use the steps below to uninstall the printer driver if your printer does not appear in the Programs menu.
Note: You will not be able to complete these steps, if User Access Control is enabled in Windows Vista. Click here for steps to temporarily disable User Account Control, so that the printer driver can be removed.
  1. Make sure your printer is connected and turned OFF (or the power cord is unplugged).
  2. Turn on your computer and log on as Administrator.
  3. Open the Printers window.
    For Windows Vista
    Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    For Windows XP Home Edition
    Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    Right-click the Canon printer icon for your model printer and click Delete.
  4. Click 'Yes' to proceed with the deleting process.
  5. Click 'OK' to acknowledge you have deleted your default printer.
  6. Click 'File' from the Printers window then click 'Server Properties'.
    Note: For Windows Vista, click your right mouse button on any empty space within the window, and then select 'Server Properties' from the menu that appears.
  7. Click the 'Drivers' tab. Select your Canon printer from the list and click 'Remove'.
  8. Click 'Yes' to proceed with the deleting process.
    Important (Vista Users): If you turned off 'User Account Control', go back to User Accounts and turn it back on.
Follow the steps below to reinstall the printer driver:
  1. Turn off the printer.
  2. Connect the printer cable to the printer and the computer.
  3. Turn on the computer, and start Windows.
  4. Insert the Canon Software Setup and User's Guide CD-ROM into the CD-ROM drive. Setup Starts automatically.
    Note: If Setup does not start automatically, click 'Start' and then 'Run' from the taskbar. In the 'Open' box of Run window, type x:\msetup.exe (where x: is your CD-ROM drive letter). Then click 'OK'.
  5. When the Master Setup screen is displayed, click the 'Custom Install' button.
  6. Uncheck (click on the check marks) all items listed except for 'Printer Driver', and then click 'Next'.
  7. When the License Agreement appears, click the 'Yes' button after reading the agreement, and then click 'Next'.
  8. File copying begins. After all files are copied, the Printer Port dialog box is displayed. When the dialog box is displayed, turn on the printer.
    Note: If the port is not detected at this time, disconnect the cable from the printer and reconnect it.
  9. Click 'OK' to end the printer driver installation.
Note: If you previously used a Canon printer that was connected with a USB cable, a message reporting that the USB driver will be updated may be displayed. Click the OK button to update the USB driver and restart Windows.
Temporarily disable User Account Control
Note: In Windows Vista, the 'Remove' button will not be accessible (grayed out) if 'User Account Control' is enabled.
-To disable 'User Account Control' temporarily, open User Accounts from Control Panel.
Click 'Turn User Account Control on or off'.
-Click the check box next to 'Use User Account Control (UAC)...' to remove the checkmark, and then click the 'OK' button at the bottom of the screen.
-Click 'Restart Now'
-Once the computer has restarted you will be able to remove the driver.
I hope it helps!!!
Sep 06, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Got virus, got rid of virus, cant print, not recognizing printer, uninstalled and reinstalled but wont finish saying "The specified print monitor is unknown"
Need to know more about the printer make and model to diagnose this completely. But the first step is to take the third party applications and software issues out of the equation.
For PCL printers setup and print to the printer using the "generic-text only" driver in Windows. For any PS laser printer, you can usually use the laserjet4 PS driver. If attached USB, unhook and plug the printer into a different port first.
If you still can't print, the print monitor in Windows was probably corrupted and you will have to run a repair using your original system disk. This happens often with virus which replace system files in order to hide from AV scanners.
If can print, then you (1) probably have an injet and (2) probably have a failed uninstall of the print applications. Third party print applications still running as a service can cause this same issue.
Jul 23, 2008 | Lexmark Office Equipment & Supplies
Driver Installation
  4. A window showing the progress of the uninstallation is displayed. Wait until the "Uninstall successfully completed" message is displayed, and then click 'OK'.
In Window XP or Windows 2000, use the steps below to uninstall the printer driver if your printer does not appear in the Programs menu.
    For Windows Vista
Dec 30, 2007 | Canon Pixma iP6000D InkJet Photo Printer
HP LaserJet 4 plus Printer Logo
108 people viewed this question
Seeker5211
Seeker5211
