Question about Toastmaster TMGM48 Countertop Gas Griddle
Pilot light won't stay lit on toastmaster griddle
What happens when you turn on the pilot light on a Capital Gas Cooktop and cook with it on
you have just triggered an exothermic reaction of light hydrocarbons and oxygen as a result of introducing an external heat source trigger. Which could possibly result in the cooking of some dinner. Yum.
No worries Barbara, you have done no damage. Unless dinner burned....
Feb 27, 2016 | capital Precision GCR486G 48" Pro-Style...
Will not stay lit
There is a piece that senses the pilot that can go bad. Usually a piece of copper with a bulb right in front of the pilot on one side that screws into the gas valve try replacing that
Sep 06, 2014 | Wedgwood Wedgewood RV Range 21 In. With...
The burners light, but it takes an inordinate time for them to stay lit. One of the burners will not stay lit when the knob is released, regardless of how long you depress the knob.
Need a new fsd ( looks like a small brass pencil) for the burner that won't light. The alignment of the ignition electrodes needs looking at and there over all condition I. E broken , worn , misaligned ect
Jul 13, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
How to relight the pilot light?
There is an easy way to relight a pilot light in an oven/broiler if you do not have long fireplace matches and you are scared to stick your arm in with a regular lighter: Light a long stick of incense, but do not blow out the flame. Open the broiler door. Turn the oven to "broil" and extend the lit incense stick in \to the back of the broiler space. Wave the incense stick slowly back and forth below the broiler coil towards the rear of the oven until you hear the pilot light ignite, then pull the incense stick out, blow out the flame and insert into an incense holder.
Sep 19, 2010 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
My oven want light its gas and the the pilot light islit
Is this a standard gas cook-top there maybe some small particle blocking the area where the gas comes out and lighting with the pilot. If you feel comfortable try lighting it with a match. First make sure there is not a lot of gas build open, so if there is a window near the stove open that and make you have plenty of ventilation before striking said match.
Mar 13, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Holiday Stove Pilot Light won't stay lit.
Wow this problem sounds exactly like my landlords problem only he is just now saying he is learning of the problem. You even have the age of the stove correct.
Jun 16, 2009 | Cooktops
Can't get burners lit.
1. make sure the gas is turned on.
2. Make sure unit is pluged in.
3 make sure all burner and burner caps are aligned.
If you hear a spark and you small gas it should light.
Make sure the burner heads are not clogged.
If this top has pilot lights make sure the pilots are lit
Nov 23, 2008 | Cooktops
Broken griddle control
Hello
It sounds like you have a short. Replace the switch is very simple. Here are the Owners Manual and the Instalation Instructions.
  • Owners Manuals (1)
  • CCGP2720P.pdf (942.48 KB)
  • Jun 28, 2008 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
    Rv cooktop range 22 series
    hi,
    it sounds like the oven safety valve is bad, it will reach a point when the pilot will make enough energy to keep itself lit, but not enough to open the gas valve to light. it will need to be replaced. if you are handy you can do this, but make sure you shut off the gas to the range first. you should be able to find a replacement online, if not check with a local LP gas company that sells parts to the public.
    Feb 25, 2008 | Cooktops
    Toastmaster TMGM48 Countertop Gas Griddle Logo
    Top Toastmaster Cooktops Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Toastmaster Cooktop Expert? Answer questions, earn points and help others
