Denon rcd m38dab
When you play a cd it plays it at very high speed skipping through the track every 10 to 20 seconds
  • 119 Answers
SOURCE: CD Player Acting Up
some cd players have a feature that is called intro. it plays typically the first 4 to 10 seconds of a song & goes to the next track. it does this to every song on the cd. see if intro is on your display or if it's turned on in the menu. i hope it works. good luck.
Posted on Jan 04, 2007
SOURCE: cd's skip
all the rca's have been released without quality control... you will have to open and adjust the potentiometers (the adjustible resistors on the main board) to re-calibrate the laser timings. However the way that the boards are mounted inside the boombox's chassis you will need to take apart everything to be able to reach the main board (inside vertical right side board with large heatsink and fan) without causing a short (as to be able to properly adjust these you need to have a cd playing and the whole thing needs to be upright.
I would recommend throwing it all way, not worth the time if you don't have the patience.
Posted on Oct 15, 2008
cdj repairs
  • 68 Answers
SOURCE: Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Posted on Dec 13, 2008
localwonder
  • 6784 Answers
SOURCE: CD player not tracking right
These are the early signs or optical lens assembly failuer. i would start preparing to replace this assembly. the tracking motor and rail are damaged.
Posted on May 28, 2009
  • 23 Answers
SOURCE: Alpine CDM 7874 won't play rest of CD after track 1.
It could be a bad burn or an issue with the receiver. Try re-burning the CD and see if that helps.
Posted on Jan 14, 2010
My Sony CDP-XA7ES CD Player can play only up to 6 to 9 tracks depending on the length of the tracks n then stops.
replace the spindle motor. the motor's speed varies while playing cds and a worn motor will not keep to the correct speed for playback of certain tracks on various points of the disc and will cause skipping and even stop altogether.
hope this helps.
Apr 02, 2010 | Sony CDP-XA7ES CD Player
Jan 14, 2010 | Alpine CDM-7874 CD Player
Cd player showing error 43
Still under warranty?... check that.
Mar 24, 2009 | 2008 Hyundai Elantra
Increasing static and complete sound loss
hello you mean buzzing,humming cause is a high missing broken ground and it needs service by electronic shop............make shure is not missing any wire that must be connected or undervlotage working............saludos
Jan 08, 2009 | Denon DCM-280 5-Disc CD Changer
Regards.
Nov 28, 2008 | Denon Dns1000 Table Top CD Player CD...
How do I copy a CD on my denon CDR-W1500
Operating instructios can be downloade here:
http://www.retrevo.com/s/Denon-CDR-W1500-CD-Players-review-manual/id/363ci860/t/1-2/
10 COPYING PROCEDURE
About copying
 Copying can be performed easily from the set’s CD unit onto the CD-R unit.
 There are two copying speeds (normal and high) and four copying modes.
• The mode switches as described below each time the normal speed copying button (NORMAL) or the high speed copying
button (HIGH) is pressed.
• The recording level is automatically set to the default value (0.0 dB).
• The repeat and random play modes are canceled when the copy mode is set.
• During normal speed copying you can listen to the sound as you copy.
• During high speed copying no sound is produced.
• No signals are output from the digital outputs during high speed copying.
• During copying, buttons other than the CD or CD-R stop buttons do not function.
• When CD TEXT compatible CDs are copied, the disc names and track names are also copied.
 When copying, switch the relay mode to the normal or dual mode. Copying is not possible in the relay or mix mode.
 For optimum recording, make sure there are no fingerprints, scratches or dust on the signal surface of the source side CD or
the CD-R/RW.
 The auto track function is always activated in the copying mode. It is not possible to assign track numbers manually.
Disc dubbing: In this mode, entire CDs can be copied onto CD-R/RW.
(“All Tr Dubb” is displayed.)
Make CD: In this mode, entire CDs can be copied onto CD-R/RW then finalized automatically.
(“Make CD Dubb” is displayed.)
1TR dubbing: In this mode, single tracks on CDs can be copied.
(“1Tr Dubbing” is displayed.)
Scan REC dubbing: In this mode, the desired tracks can be selected from CDs and copied.
(“Scan Rec Dub” is displayed.)
Jan 14, 2008 | Audio Players & Recorders
Player stuck in scan mode
Hi...
Unplug it from the wall...give it a couple minutes. Try playing a CD again (using manual controls) If that works , your remote might be the issue.
If you bought the thing new you paid good $$ for it.
It's worth having it looked at by a Pro.
Oct 22, 2007 | NAD C521 CD Player
HELP!!! My cd player just skips through all song never playing....
Sorry but this unit has a problem with the tracking servo. The problem could be an alighnment, or a bad componet such as the laser assembly, tracking motor or tracking driver IC, with all of these problems the unit will need to come out of the vehicle. Good Luck
Apr 03, 2007 | Blaupunkt Chicago IVDM-7002 Car DVD Player
CD Player Acting Up
Jan 04, 2007 | Aiwa XP-R230 Personal CD Player
15 people viewed this question
 Grubhead
Grubhead
