Question about Karl Storz 20133120 300 watt xenon Light Source
Dear sir, good day to you , i have problem in Xenon nova 175 , after 5 minutes from running the light source the bulb get off after it starts blink . kindly, can i know the problem
Lights keep blinking
Hi, Anonymous if your headlight is not working the first thing to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply to headlight bulb socket.
2. Faulty hi/lo beam switch.
3. Faulty ignition switch.
4. Fuse is good but no continuity on both sides.
5. Faulty wiring between battery positive and headlight bulb socket.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
How to install HID Xenon kit with Anti Flicker Capacitors Error Code...
Motorcycle LED Turn Signal Flasher Relay Blink Rate Fix Honda
https://dl.dropboxusercontent.com/u/35177464/TNT/1130/TnT%201130%20Workshop.pdf
https://dl.dropboxusercontent.com/u/35177464/Benelli/Cnunes%20Manuals/TNT1130%20Parts%20Manual%20-%20Cnunes.pdf
https://dl.dropboxusercontent.com/u/35177464/TNT/1130/TnT1130%20Owners%20Man.pdf
Aug 04, 2014 | Benelli TnT 1130 Motorcycles
One xenon under counter light is flashing
That particular lamp may be failing.
Jan 25, 2014 | Kichler Lighting Home
How to reset the lamp counter on light source storz 20132020?
hold "o/i" + "M" for about 5 sec
then press "o/i" + "+"&"-" for about 5 sec
press and hold "O/I" + "M" to return
something like that
Sep 26, 2013 | storz 20132020 175 watt xenon Light Source
I have no head lights at all just park lights they worked fine yesterday
Check your fuses and relays. Bulbs usually do not go out in pairs but you should check them too. It fuses relays and bulbs are good start checking the wiring there has to be a short somewhere. Good luck wiring is a night mare.
Sep 25, 2013 | Street Glow White Xenon Replacement...
EQUIVALENT XENON BULB FOR BMW K 1300 GT
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
6000K Full Xenon HID Conversion Kit
Amazon com xenon hid bulbs
http://www.carlsalter.com/download.asp?p=347
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
May 12, 2010 | 2008 BMW K 1200 GT
Infocus X1 Projector started with 3 blinking red lights.
Its due to lamp Ballast power supply is faulty,it need to repair or replace otherwise again it will damage Lamp so be careful
Mar 09, 2010 | InFocus X1 Multimedia Projector
Compac MP 1600
your prblem will be in motherboard or in power pack module-start to change powerpack module first then motherboard second- or pass it to good sevice center.
Dec 25, 2007 | Compaq MP1600 Multimedia Projector
Tv cuts off and green light flashes
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Karl Storz 20133120 300 watt xenon Light Source Logo
85 people viewed this question
Top Karl Storz Medical Experts
Andrew Taylor
Andrew Taylor
Are you a Karl Storz Medical Expert? Answer questions, earn points and help others
