Question about Refrigerators
I have a kitchen aid side by side model ksrs25qdwho3 . the refridge side is not cooling while the freezer side is working great. something frozen up? fan /blow dead?
  • sdynna May 17, 2009
    i used a heat gun and thawed the coils . so built up with ice there was no air flow. g and oing to let it run a few days and check coils again. if frozen up again what do i replace so i cycles through defrost.
  • Anonymous May 18, 2009
    solid ice on coils. will attempt to get schematic for the fridge. thanks
    President:
  • 1,136 Answers
Hi, Look in the freezer for a frost build up on the rear panel. Also listen for the evaporator fam motor. Please let me know and I can help you further.
Thanks
Vic
Posted on May 17, 2009
  • Victor
    Victor May 17, 2009
    If it was frosty and not solid ice, there are three parts to the defrost cycle. YUou should start by removeing the rear cover again and check continuity on the defrost heater and the termination switch (most be cold in order to test the termination switch). If both of these test good, then you will need to change the defrost board which is located in the control panel in the fresh food side.
Freezer not getting cold and dripping water
I own a similar Kitchen Aid fridge that had a defrost icing issue: Kitchen Aid KSRP25FNBL00
> Ice had plugged the drain hole at bottom of chill coil section inside the freezer compartment.
> I learned that the coil, circulation fan was not working, but condenser was working.
> I paid a tech to replace the circ fan, about $200, including a new swiss-made fan. He said it was unusual for these fans to fail, but not unheard of.
Expensive, but saved the purchase of a new fridge. Has worked great for 6 months since then.
HOpe that helps.
Al Zayha
Mar 09, 2014 | KitchenAid (KSRD22FKST) Side by Side...
Side by side kitchen aide 48"
What is the model number of the unit?
Nov 12, 2012 | Refrigerators
Have a kitchen aid side by side refrig that stopped working tonight. Model KSRB25FH with ice maker. Noticed ice was wet earlier today and tonight food has thawed in freezer section and refrig was not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 07, 2011 | Microwave Ovens
I have problem with my freezer. Doesn't freeze up? The model is ksrl25f side by side kitchen aid.
heatman101
Aug 02, 2011 | KitchenAid Refrigerators
Refridge not cooling in freezer or fridge
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
May 15, 2010 | Maytag MSD2456G Side by Side Refrigerator
The freezer is not freezing, the fridgerator is not cooling
heatman101
]578og
May 12, 2010 | KitchenAid Superba Architect KSCS25INSS...
Freezer not freezing on side by side fridge
Try turning the unit off and leaving the door open for half a day or more in case there is ice clogging something somewhere? If there is no cooling going on whatsoever and fan/s and compressor are running it sounds like a gas leak has devaloped or the compressor has stopped working correctly. If the compressor has stopped then possibly the controll circuitry to it has a problem.
Hope this might help
Dec 01, 2009 | Ovens
Upper freezer is working but the temperature in the fridge part is approx. 65 degrees -- not cold.
This is a malfunction of the control board. The control board is telling the refridge side that it is plenty cold - so it doesn't divert the cold air needed to keep the refridge side cool enough. Check to see the the coils in the freezer are frozen - if they are, unplug the unit and defrost with a hair dryer. Dry up the water and turn it back on - that should solve your problem.
Aug 22, 2009 | Refrigerators
Moved refrig this morning and now it is not cooling... freezer works great
Hih, Check and see if something has stopped the condenser fan motor down by the compressor from turning. Sometimes this happens in a move.
Also make sure the controls didn't get turned to wrong settings. Make sure evaporator fan motor is working in freezer and that there is no frost building up on the rear panel.
Just some ideas to help you.
lease let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
Kitchen Aid Superba...freezer shuts off..
sounds like your defrost drain is frozen or blocked its in the freezer side under the back panel beneath the evaprator
Jun 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
128 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
