Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water periodically leaking from under refrigerator
Not from input water line. GE Model 203C1412P004(?). 25 year old Side-by-side 27E
  • 4 Answers
We had this problem. Repair guy took all contents from freezer, defrosted it. There is a hole near the bottom in the back. It is for overflow. It was clogged or too full. Make sure the hole is cleaned out. Works fine now.
Posted on May 18, 2009
Water line leaks where line enters refrigerator
My 5 year old GE GSL25 refrigerator is leaking as well when using the water dispenser in the door. Removed kick panel to see better. The plastic water line on the door side of the union was improperly installed in a metal clip such that it was being crimped. This unintended pressure caused the water line to eventually fatigue and split. The door side of the water line needs to be replaced.
Oct 16, 2010 | GE GSL25JFPBS Side by Side Refrigerator
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water is leaking onto the floor directly under the freezer of my side by side g.e. refrigerator. Water is frozen in bottom of freezer floor. Is this a costly fix? Refrigerator is 10 years old.
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
G.E. Side by side model quit dispensing water. The refrigerator door was not completely closed overnight. Is is possible the water line froze since the freezer had to run so much
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water line leaking
unscrew the back panel and look if the plastic hose for the water (on the left side, goes to the blue/red valve block) is broken. If it is then you can buy a silicon tube or hose in a hardware store which fits on both ends (measure the diameter) you also need to buy two metal rings with a screw (don't know the name of these) which you can put over the connection to tighten it. The old hose has become very brittle in my case and this solved the issue
Feb 09, 2009 | GE GSS25LGM Side by Side Refrigerator
GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
Not getting water from dispenser in door
The connector that is leaking is bad causing tubing to come out and leak. The reason it won't flow is it is iced up inside of the door and no, unfortunately, you can't disassemble the door to get to it. It requires a door replacement. The connector is part number WR02X10471 from www.geappliances.com or GE Factory Service Parts at 1-800-626-2002
Dec 20, 2008 | GE Profile¿ Arctica® Energy...
Water leak from under fridge when water dispenser is used
The water line is broken somewhere from the water dispencer all the way down to the water valve. I usually find that it is broken next to the water valve. Hint: Water valve is blue and located behind the fridge in the compressor department. Water line is 1/4inch clear tube that is probaly now a "yellowish" color. Easy to spot, easy to fix, especially if located next to water valve...
Nov 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE refrigerator
this may be water from the defrost cycle. if this drains to tray over compressor, check tray is not too full (water evaporates from heat of compressor) otherwise defrost water will go to a seperate container which may have a split or is overflowing. fault can also be caused by poor door seals which would produce too much ice on evaporator pipes
Mar 21, 2007 | GE GSS25JEMWW Side by Side
GE (PSS26MSRSS) Side by Side Refrigerator Logo
253 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
