Question about NexxTech Computers & Internet
BATTERY WILL NOT CHARGE
LAPTOP WORKS WHEN ITS PLUGGED IN BUT IT WILL NOT CHARGE,,,IS THERE A DRIVER TO MAKE IT WORK.IF SO THE UNIVERSAL BATTERY FOR A DELL LAPTOP....MODEL NUMBER FOR THE BATTERY IS 2737005
  • 159 Answers
SOURCE: not charging
Dell PA-10 & PA-12 have internal serial ROM chips that communicate with the PC via the tiny center pin in the powerr plug.
If that pin gets bent or is not making proper contact, the laptop USUALLY complains and runs from AC adapter but refuses to recharge the battery ..
Posted on Apr 16, 2008
Al42
  • 72 Answers
SOURCE: My Dell Laptop battery doesn't work if its not plugged in
You could replace the cells in the old battery if you want to bother opening it up, getting new cells, soldering them together and resealing the case. Unless you're used to doing that kind of work, it's probably not worth it.
But it appears that the battery has reached the end of its life, so nothing you do to it will make it work again.
Posted on Sep 10, 2008
  • 998 Answers
SOURCE: Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
Joed911
  • 4338 Answers
SOURCE: Replacement battery for Dell Inspiron 1501 won't charge
If your old battery was doing the same (not charging), then is is because the charger is not charging the battery. Do you have a friend with a Dell laptop? Maybe you can use a borrowed charger to test and see if it will charge the batteries. To answer your question , no Dell does not have anything built in to prevent you from using a 3rd party battery.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 28, 2008
SOURCE: Dell Latitude D600 won't accept charger
Had the same problem, My other Dell charger would work fine but the original one that came with this laptop would throw an error message that the Charger wasnt recognized. None of the suggestions on the forums worked.
I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it for a few seconds and now it works fine. If you push the pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the power chord connections inside or with the adapter inside the laptop. Try it!
Posted on Aug 25, 2009
Usb powered adapters for laptops
Use a universal power adapter. This is perhaps the most obvious solution to your battery woes. Readily found at most retail outlets that carry electronics, a universal power adapter can range anywhere in price from $30 to $100 or more. The adapter comes with multiple tips, one of which will likely fit your laptop's charging port. When plugged in, the adapter will not only power your laptop, but will charge its battery as well.
Jun 18, 2012 | Acer Computers & Internet
Wall plug not working
Hi Gabriel,
Try another wall plug first. If still no good, remove the battery from your laptop and try plugging in with no battery. If still no good, test your laptop power supply with a multimeter to see if it is putting out the proper voltage. If you can't do that, buy a replacement power supply. Many stores sell universal power supplies that come with tips to fit most laptops. If it still doesn't work, take the laptop to a service shop and have it checked out.
Hope this helps!
Joe
Mar 22, 2012 | Computers & Internet
Acer Aspire 5610 battery won't charge. AC chord is plugged in. Battery reads at 3%.
either dead battery or burned out power supply try buying universal one from radioshack or best buy make sure you can return it if its not solving the problem.
Mar 02, 2011 | Acer Aspire 5520-5908 Notebook
I bought new universal adapter for asus laptop and it charges batery just when laptop is turned off
Problem description: The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause: 1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution: 1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Reference: http://www.chargerbuy.com/blog/battery-charges-only-when-laptop-turned-off/
ASUS laptop AC Adapter
Jan 25, 2011 | Computers & Internet
Plug in for the charger got damage
I work repairing laptops every day and the number of laptops i see about 5 or 6 cases of this every week, i sell universal chargers for laptops but they don't work 100% with dell. they will power dell laptops but they won't charge the battery. which end of your charger got damaged
Mar 08, 2010 | Dell Inspiron 1525 Notebook
Replaced Vostro 1400 Battery is not charging
You might have a defective ac adapter or power related problem on the system board. Go to radio shack and see if they have a tester adapter (most have universal laptop power adapters and you can try in the store to see if this works). If same issue, most like a defective battery or defective system board.
Feb 15, 2010 | Dell Vostro 1400 Notebook
Battery problem
its a battery problem try exchange it
please vote
Jul 25, 2009 | Dell Inspiron 2200 PC Notebook
Power problem with laptop
The problem may be in the charger now. It could have shorted out. Do you see any lights on the unit when it is plugged in? James
Dec 30, 2008 | Computers & Internet
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Computers & Internet Logo
44 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Joe Goldman
Joe Goldman
Prashant M
Prashant M
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
