Question about Pentair MAXITHERM 333K BTU PROPANE GAS POOL HEATER LOW NOX -
I have a SR333LP poolheater will not turn on
When i try to fire up led shows 128 and then displays r = 8. any suggestion?
Dan
  • mross369 May 24, 2009
    same model as above sr333LP. Replaced control board, then thermistor - still get the reading of 128 pool/104 spa that cannot be changed, then r=8, then it shuts down. Sometimes shows the E01 before the r=8.
  • 128 Answers
Those are not service codes. Turn top over and look at the circuit board to see what light is lit
Posted on Aug 30, 2009
SR333LP pool heater continuously cycles ON/OFF, the fan stays on
The age and over all condition of the heater would help. Try removing the Thermal Reg and see if it smooths out. If the heater responds, replace the Thermal Reg with a new one.
Jun 11, 2017 | Sta Rite Sta-Rite Max-E-Therm High...
Tip
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are...
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stands as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4 , 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13.
on Apr 17, 2010 | Electrical Supplies
Tip
Decoding Fisher & Paykel Electronic Washing Machine Fault Codes
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stand as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4, 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13 which is a pump fault.
Once the code is determined, search the web for the meaning and indicate it when requesting for an online assistance to facilitate a quick and precise response.
on Apr 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Heater does't fire. led appear 128,r13 what's problem?
128 r13 is not an error code. its the startup sequence of that heater
May 14, 2014 | Pentair Mastertemp Heater
Flashing freezer led
a flashing display is how samsung shows error codes. try and draw a picture of which segments of the display is flashing. think of the figure 8 and then try to show which part of the 8 is being shown. that is how we can tell what error code needs fixed.
Nov 02, 2013 | Samsung RS2630SH Side by Side Refrigerator
Pentair MasterTemp 400 Stack Flu Sensor Reading Stuck
check gas pressure and for clogged burn tubes unit is overheating
May 12, 2012 | Pentair Mastertemp Pool & Spa Heater Dual...
Will not turn on
The sound is the lamp that is failing to fire. This could be the lamp or the "ballast". If the lamp is an older one, change the lamp. There sometimes is an indication of the problem via the front LEDs as well. Do any of the LEDs blink? The owner's manual will contain the list of the error codes. If you don't have the manual, post the LED indicators here and we will decode them for you.
Keep us posted.
Dan
Nov 11, 2008 | Toshiba 46H84 46" Rear Projection...
Pentair MAXITHERM 333K BTU PROPANE GAS POOL HEATER LOW NOX - Logo
205 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
