Question about Electrical Supplies
Homelite generator My multifunctional digital display reads p-50 what does that mean? I have a hg5000
3 Suggested Answers
rohdd
  • 283 Answers
SOURCE: i would like to know
Find the manual here http://www.homelite.com/service_support/product_owners_manuals b> Mixing the fuel The Generator is powered by a two-stroke, air-cooled engineand requires a fuel mixture of gasoline and 2-cycle fuel lubricant. NOTE: Always mix two-cycle engine lubricant likeHomelite's Exact Mix Semi Synthetic Lubricant with gasoline before fueling theunit. Running the Generator ongasoline alone will ruin the engine. NOTE: Recommend you use ONLY Homelite or G-oil® inyour product.( Or any 2 cycle motor oil in this is not available) Use a mixture of 50 parts unleaded regular gasoline and 1part two-stroke engine lubricant (50:1). Use branded 87 octane (R+M+2) unleadedgasoline or gasohol (maximum 10% ethyl alcohol, or 15% MTBE, no methylalcohol.)
NOTE: Always mix lubricant and gas in the properproportions: 2.6 ounces of lubricant to one gallon of unleaded gaso­line. To mix the lubricant and fuel together for use: 1. Pour 1/2 gallon of gasoline into a clean gas canor other container approved for fuel storage. Do not mix the fuel and lubricantdirectly in the Generato's fuel tank. 2. Add 2.6 ounces of two-cycle engine lubricant tothe gasoline mixture. 3. Add the remaining 1/2 gallon of gasoline. 4. Close the container holding the gas/lubricantmix and swirl the can to blend contents together. NOTE: Do not mix more than you will use in a month,and shake the container to blend thoroughly before each use. Using an old fuelmixture can cause starting difficulty or damage. DO NOT USE E85 FUEL. IT WILL VOID YOUR WARRANTY. NOTE: Fuel system damage or performance problems resultingfrom the use of an oxygenated fuel containing more than the percentages ofoxygenates stated previously are not covered under warranty. Ethanol. Gasoline containing up to 10% ethanol by volume(commonly referred to as E10) or 15% ethanol by volume (commonly referred to asE15) are acceptable. E85 is not. Whenadding fuel to the Generator, make sure the unit is sitting on level ground andthat the engine is not hot. Fuelonly with recommended 50:1 mixture of gasoline and lubricant as described in Mixingthe Fuel. Toadd fuel to the Generator: 1. Cleanarea around fuel tank cap, if necessary. 2. Removethe fuel tank cap. 3. Inserta clean funnel into the fuel tank. 4. Slowlypour gasoline/lubricant mixture into fuel tank. NOTE: Filltank no higher than 1/2 in. from top to allow for gasoline expansion. 1. Reinstallfuel cap. 2. Clean up any spills. J
Thanks for using FixYa!! I provide my answer for free as a publicservice - a 4 THUMBS rating and POSITIVE Comment is really appreciated for theFREE answering of your question.
LtCmdr Spock said: "An ancestor of mine maintained, that if youeliminate the impossible, whatever remains, however improbable, must be thetruth."
Posted on May 26, 2011
richroth
  • 9472 Answers
SOURCE: The digital display for a Magic Chef gas oven reads "5 A6", what does that mean?
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds.
Posted on Mar 22, 2013
Honda generator eu3000is Not getting power to carb in order to meter fuel
After reading about Honda's Eco Throttle system available on inverter generators it seems it is not a fuel metering system but a computer controlled speed regulator or basically an electronic throttle.
Because the engine of an inverter generator doesn't need to run at a constant high speed to produce the correct 50 or 60 Hz output this generator can run at slower speeds when the load is light. The electronic throttle is the means to make it happen - operated by the computer.
The throttle is probably operated by a stepper motor and the power supplied to it likely to be in digital form. I suggest you try and gain a more full account of how the system works before you delve deeper.
Nov 09, 2017 | Honda Electrical Supplies
I have a homelite 26b leaf blower and need to mix the gas and oil. I have 1gallon of gaa and 8oz of 2 cycle engine oil
read the instructions on the 2 cycle container for your mix ratio I.E. 50:1 may equal 4oz oil to 1 gal gas etc
Oct 26, 2016 | Homelite Garden
Homelite HG600 Lightnin'bug generator. Where can I get an owner's manual?
Homelite Vintage Camping Generator - HG600 Lightnin Bug ...
? 1:23
www.youtube.com/watch?v=Amq5VLOsiN8
May 6, 2014 - Uploaded by david lum
For Sale: Great Generator 500 watts - quiet - looks like new - starts easily. Complete with owners manual.
Sep 25, 2015 | Electrical Supplies
I have homelite textorn 7500watt generator not strating ,no carunt to spark plug
You'll need to look up to see what the ohms are on the coil of that chainsaw use of a multimeter required it should have a reading between to set readings if ok then check for loose or broken wires
Feb 07, 2015 | Homelite Garden
Why generater not increasing revs under load
it depends on the load. If it is a Light or two, the generator is happy producing voltage at the RPM it is already at.
May 26, 2014 | Homelite Electrical Supplies
High voltage rpm power generator output
Not sure what you mean "high voltage rpm power generator out", however many people have asked how to adjust the engine for proper voltage output. On generators with~out a voltage regulator, I adjust the engine RPM by using a digital voltage meter that has a Hz setting. Adjust the governor untill the meter displays 60 Hz. With the geneator producing 60 cycles, I know that the engine is turning 3600 rpm (the engine produces max hp when it is turning 3600 rpm). At this point, read the voltage output to verify that the range is between 115 ~ 120. On generators with a voltage regulator, verify/adjust that generator is producing 60 cycles then adjust voltage by turning screw at the regulator (some regulators are sealed with potting compound and can not be adjusted). If your power demands are not that great and you appliance can operate at 50 cycles, adjust governor as needed. Lowering to 50 cycles will also reduce output voltage. Good luck
Oct 10, 2011 | Coleman Powermate Powermate 5000W...
I have a hg 6000 homelite generator, runs great but does not give me any power. i used it a year or so ago an everything worked fine. got a lil smoke from where windings are. the generator was made in...
Hi and welcime to FixYa. I am Kelly
This is going to sound odd but.... this is how it it is recommended to field flash and inverter type generator. (Brushless) The steps are to (not kidding...) use a male mail interconnecting wire from your house wiring and plug in your generator and turn ON the main CB for 1 minute.
If this does not work.... See steps below amnual links.
Owners manual link: (Click on get manual)
http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/hg6000_1.html
Or try this direct link:
http://lawnandgarden.manualsonline.com/support/homelite/portable-generator/request-manual-299128
This is a brushless generator... Not sure what the smoke was but... the yellow wires are for the capacitor winding. If you probe the capacitor terminals with one of the wires disconnected with a meter on R x 10,000 you should see a brief jump in resistance and then the meter drifts to infinity.
reverse the test leads and test again looking for the same result.
Next read resistance Yellow wire to Yellow Wire (Stator capacitor loop check) It should read low resistance
Also read Brown wire to Brown wire. This is the DC stator loop check. Is should read resistance.
Main winding checks Red to Blue and White to Brown that goes to the main breaker. OR Turn the Main breaker on.. White to lower left pin of 30A 4 pin output recepticle. Bot red to blue and White to Brown MUST read low resistance
These are all the checks except the rectifier and the rotor. You will probably find something during the above tests. If not... respond here and I will pass on the rotor and diode tests.
Kelly
Aug 27, 2011 | Electrical Supplies
I would like to know the exact ratio of oil and gas of my homelite 720 generator,i lost the manual and i have to be more specific in fuelling it.what does it mean by 50 is to 1? thank you
May 26, 2011 | Office Equipment & Supplies
I have a Homelite chainsaw 330 and want to know the ratio for mixing my oil with gas. An early reply will be greatly appreciated!
50 to 1 or on oil it will say 50:1. It means 50 parts gas to 1 part oil.Usually 3 to 4 ounces of oil to 1 gallon of gas. The truth is it will not hurt to put in slightly too much oil. It will just smoke more out of exhaust & prematurely foul your spark plug. If you put in too little it will hurt the engine.
Sep 24, 2010 | Homelite Garden
The coleman voltage generator for 250 kva gen set
Well I assume that this generator is NOT three Phase, and delivering 440 Volts? in that case, that reading is what is called and "Open Circuit" reading, with a full load, that reading will/should come down to the nominal voltage of 250 V (+/- 10%) This generator is a 250 V AC unit? If this is so then it is operating correctly? It is 5kw UNIT. using a digital multimeter due to it's large input impedance it will often give erroneous readings if NOT loaded down with the correct.any. load.?
Mar 02, 2010 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
19 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
