Question about Bosch Exxcel WVT 2850 Front Load Washer / Dryer
Washing machine will not start cycle
When i turn machine on the display panel shows f16 and it bleeps several times but will not start its cycle.
4 Suggested Answers
  • 1382 Answers
SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
Posted on May 19, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: F14 fault on Bosch Maxx 7 I have low water power,
Hello
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
You may need to restart wash cycle.
Posted on Apr 06, 2011
kevin_getz
  • 1031 Answers
SOURCE: f16 error code on washing machine
Posted on May 07, 2012
What does error F:16 indicate?
no one will know without a MAKE and MODEL.
Dec 26, 2015 | Washing Machines
F16 showing on display
F16 measn a problem with your door lock.
The machine senses the door is open and will stop. The door lock isn't that expensive and should solve your problem. If that doesn't solve it then you may have a faulty control board.
Try the first choice. Good luck.
Aug 24, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Can't get a Bosch MAXX 5 WAA24161GB to start. Changed fuse and socket, but machine still won't work?
hello, have you checked the glass fuse inside the washer make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
Mar 06, 2011 | Bosch Washing Machines
My machine keeps bleeping to tell me the cycle is finished but will not begin another programme ?
1. Set the cycle knob to any "X" (reset) position
2. Press and hold the Pre-wash and the Start buttons at the same time. While still holding these buttons, turn the unit on by pressing the On/Off button
3. Keep holding the Pre-wash and the Start buttons until the digital display comes on (about 5 seconds)
The digital display will show 00 for no faults or will show a fault code.
To end the test program turn the washer off at any time
Let me know what error codes come up, if any.
Nov 25, 2010 | Bosch Washing Machines
My Zanussi zwf1650w comes up with a message draining 0 0 after about 30 seconds of starting a wash cycle. The machine the stops and bleeps saying cycle ended, is there a solution to fix this?
zanussi zwf1650w washing machine. when starting any program after a few seconds machines stops and shows draining 0.0. have done diagnosis test and shows fault E91 & E48 fault codes also shows E34 code. any help much appreciated.
Nov 05, 2010 | Zanussi ZWF1650W Front Load Washer
UL in digital display coming on during wash cycle. When washer is spinning during wash cycle it is very loud and the washer moves. We have had it repaired a couple of times. It will work for several...
Hi
Thanks for using FixYa. ULis displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 27, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washing mashine dispalys symbol not in users manual.Where time is displayed it shows a symbol that look like a padlock.The machine does have a key symbol on side panel. Door is showing unlocked. Cannot...
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
Mar 30, 2009 | Electrolux EW1000i Front Load Washer
Shows "LE" in display.
Machine has a bad motor or "stator" on this machine. It is a direct drive winding on the back of the machine. Remove the back panel, the one bolt removes the rotor then you will see the stator winding, replace it and your good to go.
May 11, 2008 | Washing Machines
"LE" error means the motor has overloaded. There is no way to fix this yourself. You will probably need a new motor. Call for an engineer.
Jan 20, 2008 | LG WM-1480FHD Front Load Washer
Display panel (cont.)
hi there try pressing and holding the start button for about eight seconds
Oct 10, 2007 | Hotpoint Aquarius WD640 Front Load...
Bosch Exxcel WVT 2850 Front Load Washer / Dryer Logo
11 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
