Need instructions on installing u2cr-701
Need instructions on installing bytecc u2cr-701 internalhighspeedcardreader/hub bytecc
How do t hook the wires for the firewire connector and the usb connector on my mother board they don/t match (ASUS P4C800/P4R800).
Posted on May 30, 2009
Restore my laptop to factory settings
Hi well you can ONLY do this with an external USB connected DVD, or USB memory stick. You would need to use the DVD and Boot up off the EEEPC DVD that came with the PC, or download a copy from the net, and then simply follow instructions. The same applies to the USB drive, you would need to make a install disk, using the software and a PC.
http://www.youtube.com/watch?v=6tMnkhWXO5U
http://wiki.eeeuser.com/howto:usbrestore
http://www.linux23.com/torrent/eeepc-701-restore-discs:2e65698e76975d3cb4ee4259f2e5095f179feca4
above are links for how to do it the last link is to download the restore DVD
Oct 11, 2011 | ASUS Eee PC 701 Notebook
I have windows 7 and the Bytecc bt-144 will not work. the drive is not recognized and when i attempt to update it with the driver from the Bytecc web page the computer say the driver isup to date and will...
you might be installing the driver through the right process
click start right click on computer select properties device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
hope this helps you
Jul 25, 2011 | BYTECC (BT144) External Floppy Drive
My BYTECC USB Portable Diskette Drive was installed on my Dell Inspiron 5305 computer. However when I moved, it became unplugged. I do not know where to plug it into the computer.
if you look at the picture you can see where the usb ports are thats where the usb lead from your drive goes
sepang24.jpg number 10 is the usb ports John
Feb 02, 2011 | BYTECC (BT144) External Floppy Drive
I have a BYTECC BT-PCI-SATA 150 I/O controller card but it does not work with windows 7. Is there a driver available for this model?
I can't seem to find a product with the model number "BT-PCI-SATA" that you provided, on the Bytecc web site. You should shut off and open the computer and read the model info directly from the the I/O card to determine the exact model card you've got.
Once you which card you have, you can download drivers directly from Bytecc. There appears to be very limited support listed for both Vista & Windows 7 OSes however. If nothing else, you'll be able to download the latest version of the driver - that may support Windows 7 - without specifically stating that it does.
If you're trying to install Win 7 to boot from a hard drive connected to this controller, it may work if you supply the expanded driver on USB, floppy, etc. when prompted for a SATA driver. Bytecc only offers an email address for tech support, so you might want to send them a detailed note about the problem at: info@byteccusa.com
Hopefully, this helped - good luck!
Nov 18, 2010 | Pc Ware PC CHIPS: PC-Chip M957G...
Can't setup my Bytecc Me-850 LanDisk network storage device.
I would imagine that the drive you put in the 850 has to be formated so a MAC can see it. That would be fat 32.
Sep 10, 2009 | Computers & Internet
Unable to connect EEEPC 701 to BT HOME HUB 2
sometimes the best thing to do is start over.
reset any hubs, routers, switchers, etc.
then (just fro now) remove any firewalls,
or software that may get in the way.
You want to start with a bare minimum configuration and build from there.
eeepc works well with windows networks, the ethernet connection should just work, without additional software.
does eepc connect to other networks?
can other laptops connect to your network?
check all settings: ip address, dhcp or static, passwords, etc.
Try a "wired" ethernet connection, then try the wireless connection. if all else fails, use F9 (or DVD disk to reset/reload the system. i.e. start over.
Mar 26, 2009 | ASUS Eee PC 701 Notebook
Just wondering if a bytecc usb 2.0 drive mate needs a driver installed or if it's just plug and play. I hooked it up to my hard drive on desk top and then into a laptop and safely remove device tool came...
drivers are not required to use the bytecc drive mate for winxp or newer. detailed instructions can be found at my website http://www.brokendesktop.com
exact url is http://www.brokendesktop.com/index.php/page,Bytecc_USB_Drive_Mate.html
the jist of it is plug in drive mate to hard drive, power up hard drive wait 5 seconds plug into usb.
hope this helps ;)
Dec 27, 2008 | Computers & Internet
BYTECC BT-300
hi dear
Make sure you plug in the power for the drive first, let it boot up for a second, THEN attach the adapter and the USB
oke
Mar 22, 2008 | Computers & Internet
Software for 500GB
I don't think BYTECC sells complete external hard drives. But they do sell the enclosures. People buy the enclosures and install a hard drive in them and, now you have a working external hard drive. I have don't this before, but I have never used BYTECC before. You can download the drivers for there enclosures at there website:
http://www.byteccusa.com/
They have several different versions, Just pick the correct one, hopefully the enclosure has some markings or a sticker identifying the model.
Nov 17, 2007 | BYTECC 1 Bay ME-350U2 USB 2.0 External...
Televison & Video Logo
349 people viewed this question
Top Televison & Video Experts
Electro Med Services...
