Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Purple rolling horizontal lines across screen
As TV warms up,purple lines roll faster horizontally across screen.Picture is dim also.
    New Friend:
I have the same problem...
Posted on Jan 20, 2014
3 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Mitsubishi TV had horizontal lines across the screen and rolls up
Answer
ONE: Yes, the speaker mounted close/near to the set can be a cause of mischief; please move it further away and see if that helps clear up the problem. But, you must keep it away for several days before you will know for sure because it takes some time to degauss all the internal parts that may have become corrupted by the magnets in the speaker.
TWO: Yes, any set can be repaired the question is cost and wisdom. Old sets are sometimes not worthy of the repair simply because of the likelyhood that another failure will follow soon after. A big screen always invokes a repair charge of $200 and up. After a few of these you will wish you had put all the money into a new set!
THREE: The lines are most likely a problem in the vertical blanking circuits of the set. These are horizontal retrace lines that are supposed to be blanked out during vertical retrace of the raster. Think of it as a paintbrush that scans across the screen painting thin lines and when you get to the bottom of the screen it goes quickly back to the top, but during that time the horizontal, which is many times faster, has made several sweeps; so it must be blanked out during the retrace. The repair involves finding the guilty parts and replacing them. Usually this repair runs over the $200 somewhat.
FOUR: Prior to calling in a service tech try a hard reset to see if that will recover any of the circuit degradations. Merely unplug the power cord and leave unplugged for 4 hours or more. It may help. Or, it may not help; but worth a try since is won't cost you anything.
If the set is over 5 or 6 years of age it probably is not a condidate for any expensive repair. On the other hand, it is a Toshiba - and they make a fine set.
Hope this helps. Let me know if you have further thoughts.
Posted on May 09, 2009
maatmartin7
  • 1229 Answers
SOURCE: When I first turn on the TV, and until it
You will need to remove the signal board. This is the board with the RCA jacks and RF connectors. On this board there will be many components that are numbered. You will be searching for two capacitors that are bad. These are the locations and values. The first is capacitor location, C2V29, which is 16 volts at 22Mf , replace this. The next will be C2P05 which is 16 volts at 100 Mf, replace as well. And if you do have the board removed, you should, as well, resolder the pins on the convergence ICs. These are ICs are mounted on large heatsinks. Inspect the board for any and all other bad solder grounds. Thanks for asking and show a few hands of support.
Posted on Dec 12, 2010
Horizontal lines on led/tv with rolling vertically.
This sounds like a panel issue unfortunately, if its under warranty or you purchased an extended warranty great, if not your kind of SOL
Nov 26, 2017 | Vizio Televison & Video
Samsung 32" LED TV Purple Line Horizontally across top of screen
Can you please change the input device to some other you know, works? If you do not notice any problem there, look for the aerial cable going close to any power line or has interference from some other transmissions of any kind nearby.
Jul 30, 2012 | Samsung Televison & Video
Purple and green rolling lines after lightning storm
I have exact same problem...other posts have cited improper grounding from the Cable...which makes sense as the problem does not occrr with the DVD...I have not figured out how to fix it though...
Aug 12, 2009 | Panasonic TH-50PX75U Plasma HDTV
Answer
May 09, 2009 | Mitsubishi WS-55511 55" Rear Projection...
The horizontal on the screen has moved i have a 2
i have same problem it happens with my hdmi and component port.
did you ever find out what the problem was?
Apr 07, 2009 | Sharp Televison & Video
White horizontal lines on screen
Replace all electrolitic capacitors on the Proscan pcb.
Dec 11, 2007 | Televison & Video
Horizontal roll on mitusbishi 35" tv
is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Jan 15, 2007 | Mitsubishi CS-36509 TV
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
228 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
