Question about Spectra Hello Kitty Mini FRS Two Way Radio
The ptt button will not hold the channel. The channel only stays on 22.
Cant sync radios
The MU21CV radio is user programmable. Hold in the PTT button while turning on the radio. It will announce the frequency. Use the PTT button to count it up to the frequency you desire. Press the smaller monitor button to lock in your freq. Then the radio will announce the code number. Once again using the PTT button count it up to your desired code or the word OFF if you are not wanting a code. Then press the monitor button to lock in the code. At this point you can turn off the radio and turn it back on normally (without holding in the PTT). Your radios should be programmed to match one another. If you are still having trouble you may have a radio which needs repair or a bad/low battery.
Best regards.
Aug 05, 2013 | Motorola MU21CV (1 Channel) 2-Way Radio
Cannot set interference eliminator code on my second t5710
First check to see that your keypad is unlocked. You can lock/unlock the keypad by holding in the PTT button for three seconds. You will see a little lock icon when it is locked.
To set the code for a channel:
1. Press Menu until the CODE number begins to flash.
2. Press the + or - to select the desired code.
3. Press the PTT to save the code.
Note: You can set a different code ofr each channel using this procedure.
Zero (0) equals OFF.
If you continue to have problems, set both radios back to a very basic setting with all special featured turned off and see if you can communicate. Then add the desired features back in one at a time until you have what you'd like on both radios.
Best regards.
Oct 06, 2012 | Motorola T5710 (22 Channels) 2-Way Radio
Walkie talkies model gmr325-2 ic;513C-UT914 HOW DO I GET THESE TO TRANSMIT, MY HUSBAND HAS CANCER AND WE NEED THEM IN OUR BEDROOMS AND WHEN I AM OUTSIDE, TK U, TK U
In order to get the most out of your new radio, read this reference guide completely before attempting to operate the radio.
Turning the Radio On and Adjusting the Volume
1) Press and hold the key to turn the radio ON.
2) To change the volume level press the volume/monitor up or down key to increase or decrease the volume level.
3) Press and hold the key to turn the radio OFF.
Adjusting the Sound (Key Beeps)
Your radio emits a beep each time one of the keys (except for the PTT button and call key) is pressed.
The sound of the Key Beep will increase or decrease depending on the volume level setting.
To turn OFF this beep:
Press and hold the call key while turning ON the radio.
To turn ON this beep:
Turn the radio OFF and ON again.
Choosing a Channel
Your GMR325-2 radio has 22 channels you can use to talk to others. In order to speak to someone,
each of you must be set to the same channel.
To choose a channel:
Press the channel/scan up or down key to increase or decrease the channel number displayed.
Channel Scan Feature
Your GMR325-2 radio has a channel Scan feature that allows you to easily Scan all 22 channels. When an active channel is detected, the unit will pause on that channel until the channel is clear. Then after a 2 second delay, the unit will continue scanning.
Pressing PTT button while the Scan is paused on a channel will allow you to transmit on that channel.
To turn ON channel scanning:
Press and hold either the channel/scan up or down key. The channel number on the display
will rapidly cycle through the channels.
To turn OFF channel scanning:
Press either the channel/scan up or down key.
Talking on Your Radio
To talk to others using the radio:
1) Press and hold the PTT button and speak in a clear, normal voice about 2-3 inches away from the microphone.
While you are transmitting the tx icon is displayed. To avoid cutting off the first part of your transmission, pause slightly after pressing the PTT button before you start talking.
2) When you are finished speaking, release the PTT button.You can now receive incoming calls. While receiving, the rx icon is displayed.
Transmitting a Call Alert Tone
Your GMR325-2 radio is equipped with a call tone that will be transmitted when the call key is pressed.
To transmit the call alert tone, press the call key.
The tone will automatically be transmitted for a fixed length of time.
Auto Squelch Feature
The GMR325-2 is equipped with an automatic squelch system which shuts off weak transmissions
and unwanted noise due to terrain conditions or if you have reached your range limit.
Monitor Mode Feature
Your GMR325-2 radio allows you to listen for weak signals on the current channel at the press of a key.
To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Automatic Power Save Feature
Your GMR325-2 has a unique circuit designed to dramatically extend the life of the batteries. If there is neither transmission nor an incoming call within 2 seconds, your radio switches to the Power Save mode. The radio is still able to receive transmissions in this mode.
KEYLOCK ON/OFF
Press and hold the call key until the "L" appears. After 1 second, the LCD will return to the channel display.
To exit Keylock on mode, press and hold call again.
Note: While in keylock on mode, it will still receive transmissions.
ROGER BEEP
Roger Beep is a BEEP that is sent to notify the end of transmission.
Roger Beep can be heard through the speaker when Key Beep is on.
Roger Beep is transmitted even if key beep is turned off. However Roger Beep will not be heard from the speaker.
To turn OFF Roger Beep: Press and hold the channel/scan up Key while turning on the radio.
Jun 21, 2011 | Motorola Walkie Talkies 2-Way Radio
How do i put my new cls1110 on prog 1 frequency 4
The CLS1110 is a one channel radio. However the one channel can be changed to another frequency and/or PL code. With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming mode and can use the menu button to walk through the stages of programming. Use the PTT to change the settings, and the MENU to lock it in.
Best regards.
Nov 16, 2010 | Motorola CLS 1110 (1 Channel) 2-Way Radio
How do you perform a full reset on a kenwood tk-370
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor Key Off = off 1 = Monitor momentary 2 = Monitor Lock 3 = Squelch off momentary 2. Scan Key Off = off Co = carrier operate To = Time operate 3. Dial Key Off = off On = enable 4. TA key TA = talkaround RV = Reverse Off 5. Lo Key On Off 6. Priority None 1 = fixed 2 = selected 7. Fixed Priority Channel Turn selector to channel 8. Look back time A Turn selector to time in seconds 9. Look back time B Turn selector to time in seconds 10. Revert Channel 1 = Selected 2 = Last Call 3 = Last used 4 = Selected + Talkback 5 = Priority 6 = Priority + Talkback 11. Tx Dwell time Turn selector to time in seconds 12. Drop out delay Turn selector to time in seconds 13. Time out timer Turn selector to time in seconds 14. Tot Pre-alert Turn selector to time in seconds 15. Tot Rekey time Turn selector to time in seconds 16. Tot reset time Turn selector to time in seconds 17. Squelch Level Turn selector to Squelch 18. Beep tone On Off 19. Signalling And Or 20. Battery Save On Off 21. Selectable QT On Off 22. Clr to transpond On Off 23. Del/ Add On Off Pressing (Dial) allows programming of: DTMF 24. digit time Turn selector to time in milliseconds 25. inter digit time Turn selector to time in milliseconds 26. First digit time Turn selector to time in milliseconds 27. Rise time Turn selector to time in milliseconds 28. Rise time with QT Turn selector to time in milliseconds 29. PTT ID Off 1 = connect 2 = disconnect 3 = Both 30. Dial ID On Off 31. Connect ID 32. Disconnect ID 33. # of DTMF keys on Keypad 12 16 34. DTMF hold time On Off 35. Store & send On Off 36. D key assignment Turn selector to D or time in seconds for pause 37. Dtmf Signaling Off 1 = code squelch 2 = Selective Call 38. Intermediate Code OFF A B C D E F 39. Group Code OFF A B C D E F 40. Auto Reset time Turn selector for time in Seconds 41. Call Alert/ Transpond Off 1 = 2 = 3 4 5 42. Transpond On Off Pressing (TA) will allow you to program Frequencies Use selector to choose channel Press PTT Enter Rx frequency using: - the Selector Knob to change kHz; - the Selector Knob + (light) to change MHz. If no channel is Shown press the (LO) button. Press PTT Enter Rx CTCSS code Press PTT Enter Tx Frequency as above Press PTT Enter Tx CTCSS code Press PTT 1. Option Signal Off 1 = DTMF 2 = 2-Tone 2. PTT ID On Off 3. Add/ Del 4. Busy Tx 5. Clock frequency shift 6. Power Hi Low Repeat for the other channels (you've got a 32 channel radio, so it may take a while...) <end>
Sep 16, 2010 | Kenwood Radio TK 260 360 270 370 2100 3100...
I am trying to change the channel on my radio, how do I do that?
Jul 08, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
My cls 1110 walkie is stuck on channel 1, how can i change it?
Jun 09, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
CLS 1110 Programming
Not certain what order you are doing it, so I will type a brief explanation:
Mar 23, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
I have a problem
Normally in a Motorola T5700, to set a specific channel to monitor (and reply to) called your working channel, you press the Menu (center) button and the current channel shown in the display will flash. Press either the + or - buttons to change to your desired channel number which should be identical to both radios. Press the PTT button to save.
Likewise, both radios must have identical Interference Eliminator Code. To set code, press Menu till the code display blinks. Press + or - to select code. Press the PTT to save. To disable the code, select 0.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 22, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
No activation
Check if you are using the same channel and same squelch code in both radios. I´m not sure if you are talking about the PTT button, if is so, try using a audio accesory with ptt external just to be sure that your internal ptt is working or not.
Feb 03, 2007 | Motorola Talkabout T5500 (7 Channels)...
Spectra Hello Kitty Mini FRS  Two Way Radio Logo
Top Spectra Radio Communications Experts
eradiostore
eradiostore
Are you a Spectra Radio Communication Expert? Answer questions, earn points and help others
