Question about Troy Bilt 5.5hp Self Propelled Mower
I have a Briggs 5.5 hp with no spark. I changed the coil, diconected the kill wire, tried a working coil from another engine and still no spark. It is on a Yard Machine tiller with all engine controls on the engine itself. I'm puzzled! Dan
  • 7 more comments
  • lowridr273 May 17, 2009
    THis is on a Yard Machine tiller with pull start
    Sorry but I don't understand? What is main pulley slips?
    This has a recoil starter with the pawls driving it from inside of the cup on the flywheel
    I have a Briggs 5.5 hp with no spark. I changed the coil, diconected the kill wire, tried a working coil from another engine and still no spark. It is on a Yard Machine tiller with all engine controls on the engine itself. It has a recoil pullstart only. I'm puzzled! Dan
    Shut off wire is disconnected and this is a non-point system. I believe it is a magnatron.
    Flywheel magnet is strong, it holds a large screwdriver outright.
    Did all of the above. Set the gap at .013. This one's got me stumped!
    I've tried all of the above and still no spark. I bought this used and the original owner said it was always hard to start. Is it possible it has the wrong flywheel? THis machine cannot have 5 hours on it. The tines still have the paint on them!
    This has a magnatron system with no points so there is nothing under the flywheel. Been there checked that. I disconected the kill wire, actually took it right off! Still nothing. Could the flywheel be wrong from the factory?
  • 3,741 Answers
Disconnect the ground wire from the ignition module(magneto). That is about the only thing that will cause no spark. I use an in line spark tester from harbor freight $1.49. A lot easier than trying to ground the plug on the engine and watching for the spark. But yes, you should be able to see the spark easily like in the garage during the day. If there are wires coming from under the flywheel to the coil it may have points. --------------------------------------- Yes the coil IS under the recoil housing and then, under the flywheel.  The flywheel bore is tapered and mates with the tapered crankshaft. The keyway in the flywheel and shaft
keeps it from spinning on the shaft.  A nut secures it.  Use an impact wrench on the nut and/or a ******** the flywheel.  Don't put force on the cooling fins or they will break.  The recommended way to remove a flywheel is to use a puller.   An alternative, is to tap on the crankshaft top, with a brass hammer or use a punch tip on an air
hammer.   The flywheel will need to be held up and supported or upward pressure applied with 2 large prybars. (A 2 person job.) Care is needed so the flywheel doesn't crack or bend.  Also be careful to not mushroom over
the crankshaft top.  Do the coil replacement work. Replace the key.  Install the flywheel after cleaning the tapers and re-tighten the nut to 65 ft/lbs.
The flywheel is located under the recoil/cooling shroud. Its' bore is tapered and mates with the tapered crankshaft. The keyway in the flywheel and shaft
keeps it from spinning on the shaft.  A nut secures it.  Use an impact wrench on the nut or a ******** the flywheel.  Don't put force on the cooling fins or they will break.  The recommended way to remove a flywheel is to use a puller.   An alternative, is to tap on the crankshaft top, with a brass hammer or use a punch tip on an air
the crankshaft top.  Replace the key.  Install the flywheel after cleaning the tapers and re-tighten the nut to 65 ft/lbs.
There is also the possibility of a bent or twisted crankshaft depending on the severity of the impact but usually the key just shears.
------------------------ that your engine may well have contact breaker points that cause the coil to induce a current - they are hidden beneath the flywheel in a round aluminium container. As the flywheel rotates the CB points open and close and its important that the gap, when they are open, is set to 15 thou.
------------- The coil has one thick wire that goes to the spark plug, and one much thinner one that is used to stop the engine when it is connected to ground - just make sure that this isn't happening when you try to start up.
please do rate the solution.keep updated,thank you for using fixya.thanks.
Posted on May 17, 2009
  • charlymonty May 17, 2009
    yes it can be possible that the wrong flywheel is been connected in the unit.as it has the connections.
    if missing in yours then its definately wrongh flywheel from factory.
    thanks.keepupdated.
  • 1,183 Answers
easiest way is to remove shutoff wire from coil and then see if you have spark - if this is a point system it prob needs points and condenser.
Thanks
Proton
  • Mandeep  Singh
    Mandeep Singh May 17, 2009
    Also check the coil to flywheel gap and clean both surfaces of rust.
    Thanks
    proton
  • 3,230 Answers
Hi There,
You need to check the dianmo(starter) of your Yard Machine, it seems like bad.
Thanks
  • Mukesh Kumar May 17, 2009
    Ok... Check that there is main pully slips when you try to start the Yard Machine.
    Yes, that pullyis used to start the engine, it helps to improve rpm's of engine.
Were is low oil sensor 13-hp.briggs
check gap on coil the gap on the points and also make sure the magnets are free of rust, the capacitor could be weak also.
Jun 11, 2014 | Briggs & Stratton Ignition Kit 2-8 HP...
Toro snowthrower coil condensor points
If you have changed sparkplug and coil and cleaned flywheel, you probably have a kill wire problem. Disconnect kill wire from coil and try again.
Apr 04, 2014 | Tecumseh Enduro Horizontal Engine 5 HP...
I Can't get a spark from spark plug
try taking the air shroud of and disconect the kill switsh wires from the coils and do a continuity from the green wire from the white plug in connector, it should be the wires to the left of the starter. then try to start it as usual. Let me know how you are doing. good luck.
Mar 25, 2014 | Briggs & Stratton Briggs Stratton Intek V...
18 hp briggs and stratton no spark
unplug oil senso still no spark un \plug shutoff wire to coil still no spark replace coil
Nov 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Troubleshouting 10 hp mower briggs &stratton wiring to spark plug
the small wire that goes to the coil is the kill switch wire grounding terminal kills the engine if you remove that wire and you get spark the problem is the wiring if still no spark replace the coil
Jun 23, 2012 | Garden
17.5 hp Briggs & Strattion has no spark
unplug the harness to the engine should be a 5-6 wire give or take then crank it look for spark if you get spark that way check the safety switches if no spark change the coil
Apr 24, 2012 | Briggs & Stratton Briggs Stratton...
Vanguard Briggs & Stratton won't shut down
Your kill wire from the switch to the coil is bad,disconnected or connections dirty...or switch is bad...try disconnecting the kill wire on the coil and using a jumper ground the coil directly to the engine or frame it should shut down if it does it is the wire or switch do the same at the switch if it shuts down it is the switch..if not the wire has a break..good luck..
Feb 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
I HAVE NO SPARK ON MY BRIGGS AND STRATON MOTOR
Try this locate your coil / magneto and disconnect the kill "shut off wire " and try to start if it starts your switch may be bad or wire broken..if still no spark using a rubber handled pliers ...Pull your plug wire and place a screwdriver or similar metal piece and in the plug wire now bring the screw driver close to the engine block or Frame if spark it is your plug..if not your coil needs replaced...not a hard job just use a business card to set clearance on your coil..good luck
Jan 18, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
No spark and will not start
remove blower shroud off top of engine.Remove grass screen first.disconnect ignition kill wire from coils,retest for spark,if no spark check kill wire,wire that was disconnected from coils for short to ground.If wire checks ok,replace coils.Forty years in small engine repair.
Sep 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I changed the coil, gas and spark plug it still will only turn over and not start what else could it be?
if it has a solinoid which has two wires going to the bottom of the carburator two things you should try one take yhe aie filter off and spray some starter fluid in the carburator it should start but just long enough to run out the starting fluid or next take off the starter cover and take off the small wire off the coil that is called the kill switch it should fire if the engine is turning over you just wont be able to shut it off but you will find out that it is the kill switch
Nov 08, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Troy Bilt 5.5hp Self Propelled Mower Logo
204 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
