Question about Pentax Optio W10 Digital Camera
Shutter button not working
I push the "take a picture" buton but nothing happens. No picture taken. Not the SD card
  • Linda Wing
    Linda Wing Dec 25, 2013
    after reading and messing with auto modes off I got the camera to finally take pictures again! But now I realized that the flash is NOT working in any mode
  • Pentax Master
  • 1,511 Answers
SD card is only a storage device for data. It has no direct function other than storing pictures. Check your power supply, usually the batteries to see if you have full power. Make certain the batteries are in properly, aligned + to the + post etc.
Check to see if the settings are correct. If all of the above are in order, then the shutter control unit may have malfunctioned and thus Good Bye camera. Not worth the cost of repair.
Lastly, contact the manufacture and ask support for their opinion.
Posted on Dec 25, 2013
3 Suggested Answers
rajdeepdutta
  • 2517 Answers
SOURCE: My Pentax K100D has suddenly stopped working. It
Hi there as per your mentioned sound or noise is says that the problem create by your camera lens guide pin. Its damaged or dislocate. So i also suggest you to visit the service center. Thanks.
Posted on Apr 03, 2010
TickMagnet
  • 68 Answers
SOURCE: I have a Pentax OPTIO
Does a different card work in the camera?
Can you read the card on your computer with a card reader?
and...check the little slider thingy on the side of the SD card, flick it up, try it, flick it down...try again.
check the SD slot on the camera, anything stuck in there? lint? dust? sand?
Blow it out with canned air.
Eliminate the card as a problem...hope it's the card then worry about the camera.
Good luck
TickMagnet
Posted on Aug 17, 2011
Nikon d300 won't take pictures
Try to autofocus first by half press the shutter button, after focus confirmed then fully push the shutter button. Basically camera won't take picture if the focus not focused correctly.
Jul 21, 2013 | Cameras
It turns on but won't take a picture when you push the button! I downloaded the pictures on the card because I was told maybe it wouldn't worked due to a full card. It did have 2300+ photos, but only 77...
The shutter button has a little nib on its end that can break off with age. This tiny piece of plastic extension is needed to fully depress the shutter switch inside the camera. There's a fellow on ebay that sells these with instructions (see this link). But sometimes you can get a better deal by buying a broken A520 with other issues, and just cannabalizing this part.
May 09, 2010 | Canon PowerShot A520 Digital Camera
My Pentax K100D has suddenly stopped working. It hasn?t been bumped or dropped or anything. A few days ago I was still taking pictures, and then a day or two later when I tried it, it wouldn?t work. When...
Apr 03, 2010 | Pentax K100D Digital Camera
I have a Kodak dx4530. Recently, when I push the
The camera is not recommending the picture, It could be overexposed, shaky or taken in the wrong SCN.
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 01, 2009 | Kodak EasyShare DX4530 Digital Camera
Coolpix L1 that won't take a picture after getting wet
try dismantling you will find a gooey substance in a microchip. try removing it.i hope it works
Sep 12, 2009 | Cameras
Nikon coolpix l16, not taking pics
Take out the media card, then do a factory reset.
Jul 06, 2017 | Nikon Coolpix L11 Digital Camera
Cant take a picture although camera turns on
2 possible solutions. !. try using another SD card. if the one in the camera is full, you cannot take a picture. 2. Try another SD card for transferring, (and taking pictures) and try transfer of this card in another camera or reader, such as the one in photo print places.
Apr 13, 2009 | Kodak EasyShare Z612 Digital Camera
Error. Press shuter release button again
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
Sep 08, 2008 | Nikon D40x Digital Camera
Samsung s630
About the memory cards to be used with this camera, those could be:
- MMC / SD card (Up to 2GB Guaranteed)
- SDHC card (Up to 4GB Guaranteed)
Some cards are not compatible according to the memory card
manufacturer and memory card type.
If that is the case, i'll be advising you to try 1 GB so it will work.
But if it still does the same thing with the 1 GB card or with whatever cards you're using, you could still take more pictures even without a memory card. It's just that you need to adjust the picture size and quality to the lowest resolution to have more pictures taken.
To change the size:
Rotate the mode dial to PROGRAM:
- Press +/- button (2nd button)
- Go down to where you're see 6M, 5M, ... 1M
- Select 1M for the lowest size
- Press MENU/OK to save changes
To change the quality:
- Go down to where you're see Dots corresponding to NORMAL, FINE and SUPER FINE
- Select NORMAL for the lowest quality
To turn off camera after the settings
have been changed to refresh the camera.
If it still does not work, you need to contact the Manufacturer.
I hope this help you a lot.
Dec 16, 2007 | Samsung Digimax S630 Digital Camera
No picture taken when shutter release is pressed
if you see no reation of the pressing of the button i.e. no focusing, no error message nothing , then most probably a simplest problem , the shutter release button may not be working for few reasons : 1) defective switch. 2) defective flex cable. 3) camera exposed to some physical jerk or dropping resulting into disalingment between inner switch and the shutter release button.
Jul 09, 2006 | Fuji FinePix S5500 Digital Camera
Pentax Optio W10 Digital Camera Logo
26 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
