Question about Vizio Televison & Video
How to program vizio remote 0980 0305 3000 vr2
How do you pause ? rewind or fast forward ?
Clarence, Read your manual, and use the button on machine or remote.
to show your appreciation press the helpful button and follow me on fixya for more tips and info.
Feb 15, 2016 | Vizio VR2 VR4 Remote for VOJ320M VO37L...
How do you set up screen size on the control?
get to the on screen menu and scroll around till you find aspect ratio alter that to the screen size that fits --ok -then exit
Sep 24, 2015 | Vizio VR2 Remote Control
I am searching for the codes and instuctions on how to set up my magnovox dvd player to my vizio E470VL remote control
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
Apr 28, 2014 | Vizio VR2 Remote Control
Vr2 has no enter button?
If so, what we can do? Nothing can be done.
May 11, 2013 | Vizio VR2 Remote Control
No enter button
Use OK button if there it is.
Reset vizio tv
Unplug the TV from AC mains wall socket, and re-plug it back after 5 minutes or so. This must make it a hard reset. There is no other procedure.
Mar 30, 2013 | Vizio VR2 Remote Control
Find my Vizio remote
Contact the authorized service center for Vizio. There is no other way.
Aug 30, 2012 | Vizio VR2 Remote Control
Codifying remote universal vizio for sylvania
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Codes to check are: 0062 0004 0009 0135 0189 0183 0227 0456 0008 0068 0075 0141 0161
Aug 05, 2012 | Vizio VR2 Remote Control
I need to manually program my universal vizio remote
1. Manually turn on the VCR/DVD/Cable set top box.
2. Press the VCR/DVD/Cable set top box button on the remote control.
3. Press and hold the SETUP button until the LED LIGHT flashes twice.
4. Enter the codes using the Number Buttons. If the code is accepted, the LED flashes twice after the last digit is entered.
If the LED does not flash twice, repeat Steps 2 through 4 with the next code listed for the component and
manufacturer.
5. Point the remote control at the VCR and press the POWER button. The VCR/DVD/Cable set top box will turn off.
6.Your are done.
Thanx
Jul 23, 2010 | Vizio VR2 Remote Control
I spilled water on it and now it won't work. Is there anything I can do to revive it?
Take the remote aparts,clean it really well,take a hair dry put it on low heat dry PCB board,should work after this,not than it dead,it garbage.Try website like Remotes.com to buy an exact remote.
Jun 21, 2010 | Vizio VR2 Remote Control
Televison & Video Logo
126 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
