Sony trinitron tv
One colour missing
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Check the video output section circuit for any loose solder or damaged component/s. Re-solder all the suspected solder terminals at this board, by applying a little more solder. This board can be located at the neck of the picture tube, will directly plugged on to it; can be pulled back to separate it for repair. The fault is knows as one 'one color predominant' screen. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Posted on Dec 25, 2013
4 Suggested Answers
  • 4234 Answers
SOURCE: Missing Green colour on 36" Sony FD Trinitron WEGA
This is not a problem that a reset will fix. THe 5 blinks is a code that indicates a problem with the AKB circuit. There is a possibility that the picture tube is starting to fail, but that is rare. If you are comfortable working inside the set where there are potentially dangerous high voltages even when unplugged, let me know and I will provide additional details and instructions for a couple of repair options.
Dan
Posted on Feb 24, 2009
  • 4234 Answers
SOURCE: I need copy of schematic drawing Sony Trinitron
Since the set recovers under some conditions, I would first look for poor solder connections. With a set of your vintage, it is common for some of the connections to become faulty. If you can solder, resolder any connections on the board that appear grainy or have rings. Please note that there are potentially dangerous high voltages present inside the set even when unplugged.
Keep us posted on your progress.
Dan
Posted on Mar 09, 2009
vljenterp81
  • 86 Answers
SOURCE: Green and yellow images appear to be orange on the screen
hello my fellow electronics tech. it seems that you know something about electronics. i would check the color transistors on the circuit board on the back of the crt neck. i believe it is supposed to be around 5v per transistor. one way to be sure is to match voltages with the other two amps and see if the green has no voltage. you then make a resistance check. make sure all power is off and the voltage has been drained from the set. check the caps by the color ic also with an esr, or use your ohmmeter.test your color ic for correct voltages that could cause erratic color problems. thank you very much and please rate my solution
Posted on Nov 17, 2009
Sony trinitron only in blacka nd white. how do I return it to colour?
pls check your tv colour system it is not maching with your country col-sys [PAL /NTSC/SCHAM] so pls open menu and set col-sys select any one or set col-sys is AUTO see the colour pictur.
* NO colour [B&W} pictur
[1] cabel singnel is wek.Pls. check cabel canaction re set pin or cabel canaction.
[2] pls tune ch. set Auto serch or fine tune to set ch.
if not colour pictur then problum is inside of your colour tv set.
Oct 05, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Can colours be adjusted manually? Some TV stations vary in colour content. How do I change the colour values?
you might find the colour & saturation levels controls. using your remote to set that up, check the tv manual... if you don't have one, you can likely find one on-line by doing a few searches.
Goog Luck... Ian
Oct 02, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Color TV - KV-27TS27 circa 1991
there,s a lose connection on vertical section of your tv. to resolve that to \resolder the vertical section but be careful of short circuit t may damage your system
Feb 28, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
KV-32FQ75E colour loss
Go to the Sony website and check out the correct antenna cable and scart lead configuration for your set up. I did and with a few simple connection changes it was like getting a new TV.
Jan 07, 2008 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Screen Image is Concave
sony trinitron colour 29ins tv its black and white not colour but the teletext is colour
Sep 01, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
