Question about Jeep 1998 Grand Cherokee Limited 4x4
Clock radio display comes and goes mainly goes, radio plays, like loose connection but which one
    New Friend:
I recommend checking the grounds
Posted on Dec 29, 2013
The radio and clock on 2008 Suzuki swift will go off and come back on a week or so later and the time would be right
fuse bad, to it or just loose.
if not bad wire from fuse to radio
or radio bad.
or ground to radio bad, unlikely do to not forgetting time and stations
the radio has 2 power wires, main power, and memory
main power is the failure here.
if it goes dead, check for 12vdc key on, to radio power pin first.
Mar 14, 2015 | Suzuki Swift Cars & Trucks
2009 Bmw lci radio display problem in hot weather
Replace it, there is thermal defect present on the main board or the display board. You have to remove the radio, disassemble and use a heat gun and freeze mist to find the part.
Sep 12, 2014 | BMW 318 Cars & Trucks
Display will not stay on
sounds like you have a lose connection
Jul 29, 2012 | Bose Wave Radio
I have a 2009 pontiac vibe with a radio that seems to ONLY work when the key is in the ACC mdoe. When I start the car, the radio and display goes off completely. When I press the Clock button the times...
Incorrectly wired, the supply going to the main power goes to the ACC only and not the main power or the ignition switch is faulty if nothing else works like blower etc.
Jul 30, 2017 | 2009 Pontiac Vibe
I can't get my 4th Gen. IPOD Nano to play on my Brookstone iDesign Cube Clock Radio.
Turn the device on
Connecting your iPod/iPhone
  1. Insert piece 17 for iPod nano (4th generation)
  2. Press and hold the iPod button until the display shows the iPod icon and the "Auto"
  3. icon.
  4. Press the iPod button again to activate Auto Play (AUTO is circled)
  5. Choose song on ipod and hit play on ipod
I hope this helps :)
Dec 30, 2010 | Brookstone (467522) Clock Radio
Lost my manual for the NP 105CR Model Next Play IPOD Dock cube. Can't figure out how to turn off a radio alarm which comes on at odd times.
The Alarm is controlled by the Set button. Press Set once, then press Function to cycle through Alarm 1 functions until the display reads OFF. If needed, press Set again, and press Function until Alarm 2 also reads OFF. Press Set a third time, and you can set the main time with the Vol +/- (minutes) and the Skip (hours) buttons. Press Set a fourth time to return to normal display.
Dec 21, 2009 | Starlite Next Play Clock Radio with iPod...
No power to cab, no power to start, but clock has power
check fuse block for shorts, melting discoloring,on back side of fuse panel around starter relay. loose connection causes fuse block to over heat will need to be replaced.hope this helps.
Oct 29, 2009 | 1997 Chevrolet S-10 Pickup
LCD light for time/date
This is a problem with intermittent display contacts.This problem occur because of heat and vibration during operation. The connection are solder to the connectors. The solder joints that make the connections expand during heating and eventually lose contact with the connection points. When you tap on the display you move the connection back into contact. This will eventually fail to happen as the connection get worse. The Clock/Radio's display needs to have the contact points resoldered. This is a service usually performed by a service center. The Emerson customer support Telephone number is 1-800-909-1240 you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of your Clock/Radio. Tell about the problem you are having with the intermittent display. They should be able to tell you how you can get the Clock/Radio repaired. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day.
Jan 11, 2009 | Emerson Smartset Clock Radio
Emerson Jumbo Display CKS2237 clock radio
Sorry it took so long to get back to you with a answer to your question. You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
Oct 05, 2008 | Emerson Smartset Clock Radio
Jeep 1998 Grand Cherokee Limited 4x4 Logo
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
