Question about Frigidaire Freezer 20.3 Cu. Ft. Frost Free Upright Freezer, AFFU2066D
253.9287412 Alarm kept going off, and now it is not getting cold at all. The compressor seems to be working and the temperature switch?
Upright frigidaire freezer light flashing 6 degrees pressed super freeze will it reset??? How do I know if super freeze button working??
Check along the back and sides of the freezer for any vent-like openings that are covered or blocked by packages. There may be a sensor that's not getting air flow as it should. Although most upright freezers are now frost free, there still can be ice buildup in critical areas such as the thermal sensor or the fan. Can you tell if the fan is running?
Even if the compressor has failed, your frozen items will keep the temp down for several days. I suggest you move the frozen goods to a neighbor immediately. Meat or fish in particular quickly becomes unsafe to eat without at least refrigeration.
Sep 03, 2016 | Frigidaire Freezers
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
My Electrolux upright freezer Model GLFU1467FWO Serial No WB61740462 ..the temperature warning light kept going off, so kept resetting it, now there is no temperature light at all, the freezer is stil
Check the condenser grille is clear and clean, and all fans are working. Get a cheap thermometer to keep in the freezer and check it from time to time.
Jul 21, 2012 | Electrolux Freezers
This unit was purchased new 61 months ago. First instance of any problems, ever, today it seems food isn't being kept frozen solid. We suspect the compressor is having a problem. There was no sound...
Yes it is a very big concern.It sounds to me like your condenser is dirty and the compressor gets hot and goes off on overload.You can tell by putting your hand NEAR the compressor.Be careful as the compressor can be very hot
Sep 14, 2010 | Frigidaire Freezers
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power
fails, the alarm will not perform.
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
freezer is shipped with the switch in
the OFF position.
After the freezer has run longenough to
lower the temperature, you
may set the switch to the ON
position.
To activate the alarm, set the switch
to the ON position.
To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
Mar 28, 2010 | Kenmore Freezer 13.7 cu. ft. Upright...
Freezer temperature went from 0 to 20 degrees farenheit and holding.I had the digital readout, alarm, and temp. setting go out 1 year ago and replaced with inside temp. guage. I have a warrnty on the...
If this is a self defrosting freeze,then it is normal to periodically see an elevated reading during a defrost cycle. At 20 degrees, it was probably ready to complete its defrost cycle and come back on to return it to your cold setting.
Dec 25, 2017 | Kenmore Freezers
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
ARISTON FRIDGE FREEZER MBA 3842C PROBLEM
It should work the same as before. Does the compressor get really hot after running a while? If so it could be low on charge, or there could be a restriction inside the refrigeration system. Either way a professional would have to look at it.
Jan 07, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Frigidaire Freezer 20.3 Cu. Ft. Frost Free Upright Freezer, AFFU2066D Logo
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
