Question about Drills
Hi can you send a parts diagram for Hilti te 35 rotary hammer drill? My dad is trying to add oil
Need to add oil
    Champion:
  • 304 Answers
Posted on Feb 03, 2014
  • 2712 Answers
SOURCE: hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Posted on Aug 27, 2008
rowdy45176
  • 2176 Answers
SOURCE: Hilti TE-60 hammer drill
what I would do if you have a fax machine is call 1-800-879-8000 and request a schematic on this tool first. Some of their products are not that easy to disassemble. I never have worked on the TE-60 but have on some of their other products and they are all different. Hope this helps
Posted on Dec 19, 2008
  • 123 Answers
SOURCE: Hilti TE 17 Rotary Hammer repair switch fix
If you are talking about the wire going from the switch to the stator it difficult to get to. You have to remove the motor end cap, cooling fan and handle holding the switch. this will get you to the brush holders. These can be brittle so you need to be carefull. Turn the motor over and tap the end of the armature on concrete checking the brush holders every couple of taps to see if they are coming out of the motor housing. after they clear they will just come out. If you havn't done so already remove the wires going to the brush holders. Your stator will simply slide out after your brush holder comes out. This will give you access to the wires to repair.
Hope this helps.
Posted on Oct 29, 2009
Testimonial: "worked well for me"
ftw1952
  • 10319 Answers
SOURCE: Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Posted on Mar 11, 2010
  • 123 Answers
SOURCE: HILTI TE 72
It could be that your connecting rod is broken. You can check by taking your shift lever off of the top of the gear housing and then removing the snap ring to remove the shift boss. That will allow you to look at the crankshaft and connecting rod. If it is broken I would check with Hilti to see if they still carry parts for the TE 72.
Posted on Mar 13, 2010
Hilti TE 74 not hammering
It takes 70 cc of oil in the gear casing. Too much oil will snap the connecting rod. If it did not have oil in it there might be a leak somewhere
Nov 06, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
I am trying to find a trigger switch for a Hilti TE72 can you help? thanks colin.
Hilti only sells parts directly...
http://www.us.hilti.com/holus/
heatman101
May 14, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti te 15-c i have a oil leak behind the chuck.
It depends on where the leak is. if you email me I can send you an exploded diagram of tis machine. This will give you an idea of how to take it apart.
paul@wysehire.gi
Apr 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
NEED PARTS FOR HILTI TE 17
hi i have a 30 year old hilti te17, yes i know but its great but i need the bit holder ( chuck i think its called, the thing that hold the drill bit in for this hammer drill, otherwise its works perfect, built to lasst these things, but parts are hard to come by in aystralia, anyone help me if you can please
lulu
Mar 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Grease for hilti te 24
any liquidy grease like lubriplate or milwaukee type Y grease part no. 49-08-5270
Oct 20, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Te-5 rotary hammer i need parts
Call Hilti direct at 1-800-879-8000 and speak to them. They can fax or ssend you a breakdown of the tool list. They will also sell you parts. I don't know of an outside source for Hilti parts. If I have helped you would you please rate my response accordingly and Thank you.
Aug 23, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Drills Logo
417 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
